How do you enable high idle on 06 G56?
Old 05-07-2007, 09:07 PM
zander79's Avatar
Just wondering how to enable the idle-up feature on my truck. Do I have to take it in to the dealer, or can I do it myself? Thanks.
Old 05-07-2007, 09:20 PM
Jim Dynomite's Avatar
Look at this thread: https://www.dieseltruckresource.com/d...=120288&page=2
..............Jim
Old 05-07-2007, 09:49 PM
wreedCTD's Avatar
bad link. i was wondering if i could enable it myself also...
zander79's Avatar
Thanks, but that thread does not work.
Old 05-07-2007, 10:07 PM
53 willys's Avatar
new link......
https://www.dieseltruckresource.com/...5&postcount=21
Old 05-07-2007, 10:08 PM
wreedCTD's Avatar
is the only way to enable high idle on a auto is thru the dealer?
Old 05-07-2007, 10:11 PM
53 willys's Avatar
I think the bully dog stuff can enable it... but I dont know for sure??
smarty may be able to also???
I am sure someone in the know will chime in
Old 05-07-2007, 10:15 PM
zander79's Avatar
Thanks. Wow, that seems like a whole lot of messing around w/my ECM wires. Dont know if I am going to dive into that one, wish it was easier.
Old 05-07-2007, 10:18 PM
53 willys's Avatar
Are you serious????
that is the easiest mod there is...all you do is ground the pigtail and plug it in...what so hard about that????
Old 05-07-2007, 10:21 PM
zander79's Avatar
No I'm not. Just have had bad luck w/ECMs, on my second one.
Old 05-07-2007, 10:23 PM
zander79's Avatar
How come y havnt done it then.
Old 05-07-2007, 10:28 PM
53 willys's Avatar
I did right after I read that post. it's easy
Old 05-07-2007, 10:38 PM
zander79's Avatar
So the $200 cummins clutch switch is must, or is it the same as a pigtail? Sorry man, I'm really bad w/electronics and wiring. I stick to welding and lift kits.
Old 05-07-2007, 10:46 PM
53 willys's Avatar
all you need is the $13 pigtail...the switch is a waste of money IMO
soon as you touch the brake it kills the high idle with the pigtail so I don't see where the safety switch would do anything anyway???
Old 05-07-2007, 10:57 PM
zander79's Avatar
Got it. Thanks for all the help. Looking forward to setting it up. I run my winch alot at work, and am sick of stuffing a 2x4 between the diesel pedal and the seat frame (I know pretty ghetto, but it worked) Aloha, Zander.
Quick Reply: How do you enable high idle on 06 G56?
