How do I check the input bearings on a NV5600?
Old 03-12-2010 | 05:38 PM
cLAYH's Avatar
So I pulled the tranny on my 2003 today so see if maybe a bad pilot bearing is causing my hard to get into gear issues. Sure enough the pilot bearing is a bit rough.
It was also suggested that I check the input bearings. Anyone know what to look for here? I can wiggle the shaft back and forth a bit, how much is allowed?
Old 03-14-2010 | 10:42 PM
RTillery's Avatar
Peter at Southbend Cutch told me to see if the shaft would wiggle enough to touch the through-out bearing tube. If not, the input shaft bearing was probably OK.
Old 03-14-2010 | 10:48 PM
cLAYH's Avatar
Thanks!
I was close but defiantly not touching. I've got it all back together now and it is defiantly better but not as good as I was hoping. I'm thinking maybe I'm just expecting too much from a truck tranny.
I'll have to go drive the old '86 farm truck with the NP435 and see how it compares.
Mutt68
09-25-2012 12:51 PM
winkdemon
09-16-2008 06:49 PM
denny G
04-27-2007 01:32 AM
getblown5.9
04-19-2006 11:16 AM
Quick Reply: How do I check the input bearings on a NV5600?
