How can you tell 2004 from 2004.5??
I just bought a 2004 or a 2004.5. Im looking to get a few performace things for it and i need to know what year it actually is? How can I tell them apart?
Originally Posted by mikmaze
congrats on the 04.5, now that means that your tps is in only one of three places ....
on the pedal for 2005+
on the engine for pre-2003.5
This is manual trans only
for autos its different (2004.5 and prior is on engine, 2005 and beyond is on the pedal).
didn't know you could get a 325 hp before 04.5, 04.5 325 hp trucks can have them in all of the mentioned locations, just ask or read the quad box threads, mine is on motor as is jeremy from quadzilla, gichugoat found his under the battery tray and others have them at the fuel pedal..... model year changes tend to clean out the parts bin.
OK now ya have me curious. What is the TPS??? In my mind it should be the Throtle Position Sensor but if thats the case i cant for the life of me figure out how it could be under the battery tray. The only way I could see that working is if its throttle buy wire and it still would make no sense to put it there and not just directly on the foot pedal.
yup, two out of three placements for the throttle position sensor still have a cable system, the one on the engine, and the one under the battery tray. precious lucky buggers get it down by the peadal and makes it so much easier for boxes that require tappin the wire. Also less prone to cable frezeup problems and less prone to trouble after washing the engine and having no throtle/
They used the under batter tray for the manual only because they had no way of replacing the "kick down" / TV cable for the auto trans. The under battery tray TPS was a cost reduction (it was the same one used on the HEMI).
They finally figured out how to do it for 2005 and had another cost reduction to go to the TPS on the pedal for both auto and manuals (using a little electric motor for the TV cable, now called the transmission throttle valve acuator or TTVA).
Totallyrad
07-19-2011 07:41 AM
acblake
02-12-2006 05:28 PM
ocsurf16
01-08-2006 10:18 PM
SuperDave4x4
07-12-2005 11:59 AM
