HO cummins vers non HO looking to buy
Old 01-28-2010 | 10:08 PM
  #31
Brad5502's Avatar
I hated my SO towing an 8K 5th wheel...pulled like an old dog up grades.
Put in a Smarty SR and a few minor mods (see sig). Now it pulls my 13.5K 5er like any HO! Smarty SR was the key. The other mods (with the exception of the Pakbrake & Airbags) probably had little impact.
Everything is still original except tires and brake pads and I'm over 124K miles..
A totally reliable truck!
Old 01-28-2010 | 10:15 PM
  #32
LeaperV12's Avatar
Originally Posted by PSYCHOFAB
when Im not towing I drive my 6 speed like a 3 speed.2 4 6 works good and fast.
Side Question :
How long have you been doing this ?
any disadvantages other than maybe some increased clutch wear ?
Thanks
Old 01-28-2010 | 11:52 PM
  #33
billie's Avatar
I do the same. There is no clutch wear if you engage your clutch before you apply power. Slipping a clutch causes wear.
Old 01-28-2010 | 11:57 PM
  #34
PSYCHOFAB's Avatar
4 years. Iv yet to put a clutch in at 158,000 miles. might of had a new clutch when I bought it at 100,000 miles but who knows.
Old 01-29-2010 | 10:05 AM
  #35
tajinate's Avatar
Originally Posted by AH64ID
Why? You have more time in the powerband with the 6-speed. I have towed with the guys who have 5 speeds, and they are hating life.. too many or too few rpms at certain speeds.... Even around town they say how much they would prefer a 6 speed.
Sounds like the like/dislike of either setup is personal opinion. The 5 speed is cheaper to buy, cheaper to re-build and a lot easier as well. I am not worried about the power band as that is very easy to manipulate on these trucks with a little tuning. With my TST on TT03 once you hit 12 PSI you are in the power band and on my truck about 2 seconds from 45 PSI. You said you have towed with guys who have 5 speeds, that is a difference as well. If I towed a lot maybe I would keep it, but towing a 2 ton boat around in the summer and an occasional Bobcat or compact tractor once in a great while, and a cord or so of cedar wood here and there, not really using it for towing a lot. This should help get the point across too, there is no goose neck ball in my bed. The reasons you have for running a 6 speed are no doubt correct, but for how I use my truck those reasons aren't really applicable.
Old 01-30-2010 | 03:29 PM
  #36
LeaperV12's Avatar
I Never touch the accelerator before my clutch pedal is out.
What about lugging ? Doesn't lugging eat away a clutch too ?
Not to hijack this thread but how bad is starting in 3rd vs the normal 2nd ?
Old 01-30-2010 | 03:37 PM
  #37
LeaperV12's Avatar
Originally Posted by MMpuller
I was looking at a 2004 that isn't the high output with a manual five speed. I was wondering what the HP and Torque was and what all was differen't. Any difference in milage? Can you just reflash the ECM and maybe replace the injectors or is there more differen't. I can live with out it being the high output but I do wonder about getting injectors later (10 years) if they have to be replaced. I just have seen very few that wern't the HO so I question parts price and if I can get them.
Thanks
Jeremy
Is the price difference between a SO & a HO significant ?
i personally waited till i found a HO but price would be a large deciding factor
and because i don't tow, sometimes i feel a 5 speed would have been easier as a Daily driver, much easier
But that's just personal preference coz i love my 6 speed too
Old 01-30-2010 | 09:20 PM
  #38
PSYCHOFAB's Avatar
I dont know about the luging, but if your clutch isnt slipping than it probly ok. Asfar as 3rd gear Im running 37" tires and that takes too much clutch.
Old 01-31-2010 | 01:11 AM
  #39
jay_d's Avatar
if you have a 6 speed with 4:11s you wont have any trouble with the 3 5 6 changing, its just like driving a 3 speed.
if its a 6 speed with 3:55s or 3:73s it might be a little tougher. we have two company trucks that are six speeds, the dually is 4:11, the dump is 3:55. the dump truck stumbles and doesnt like to start off
Old 01-31-2010 | 02:18 PM
  #40
LeaperV12's Avatar
have 373's, there is a slight stumble, when starting in 3rd but doesn't feel too bad, same for going from 2nd - 4th
Old 02-02-2010 | 01:57 PM
  #41
SOhappy's Avatar
Usually the seller of an SO won't ask for much less than if it were an HO. NADA does list both engines, and if I book my truck both ways there is no difference in the value.
If remember right- on the window sticker when I bought mine new, the HO was about a $5k add, the SO a $4k add over the gasser.
More importantly, I think a knowledgeable buyer could use the SO vs. HO debate to beat the SO seller down on price, and use the difference for power upgrades (in not already installed).
Old 02-03-2010 | 12:28 AM
  #42
retirednak's Avatar
I've had my SO since '04 and has been mostly trouble free,other then POOR fuel mileage and the crappy front end parts. I'm reaching 100K and might be close to injector and pump time.
One point on the your truck your looking at,made darn sure the front end/steering is updated with the newest Mopar HD parts. They may still be a recall on newest redesigned parts,but that is another bargaining chip. I don't care if the truck has 40K or 400K miles,if it doesn't have the newest Mopar parts or parts from Carli or others,your new truck will drive like an old K car and may even have the death wobble,plus you can't get the front end aligned with even a slighty loose front/steering issues. Also make sure the truck has had all its recalls taken care of. DON'T EVEN get the horn honk door open recall done,it SUCKS!
Its had two Recalls just recently,something to do with the front end issues and I can't member off the top of my head on the other one.
I will also be buying a smary soon and we'll see how big a difference it makes in mileage and power. I wish I knew a member locally to try their smarty,
Anybody in Alaska? And lastly,I wish I would have looked harder for a manual trans and if anybody wants to trade their SRW setup for my DRW,drop me a pm
89dieselkong
02-12-2010 12:47 AM
stock600
Competition / Pulls / OffRoad
13
02-17-2008 01:09 AM
dctoner
02-09-2004 02:55 PM
DAMAN
03-02-2003 05:53 PM
TEXWS6
10-25-2002 03:01 PM
Quick Reply: HO cummins vers non HO looking to buy
