High return injectors
I paid $30 per injector to bench test them at a local Bosch shop. If they test bad, I would reccomend new Bosch injectors, but I do have 30k miles on remans with good results in my DD. Sufficent fuel pressure and filtration should be addressed as well if you haven't already.
Dutchy, did you pull your injectors and take them in or did they remove them as part of the service? Where did you go in Western Pennsyltucky? My number 1 injector has morning sickness and smokes runs rough for a few seconds on a cold start. I believe it was bad fuel as I had a skanky fuel filter 2K miles after a filter change.
Rick 12v CTD
09-23-2011 05:21 PM
ctd4stan
05-18-2009 02:56 PM
GreenMachine5.0
39
03-23-2006 11:26 AM
