High Idle - No Cruise Control
Old 08-30-2007 | 03:30 PM
vzdude's Avatar
DTR's 'Go to Guy'
Shouldn't, so check your brake switch adjustment, Thats about the only other thing that will make it not work. The ecm looks for signal to turn on ( you have because it shows the light ) then it will deny cruise for several things - speed, brake input, key on/off, ect.
Old 08-31-2007 | 03:20 PM
hobbz's Avatar
Is there a way to check the brake switch? Is there a resistance check I can do or anything? A tried the felt pad trick and it still won't engage.
On a great note though. When I got to work today after messing with the cruise trying to get it to work the whole 6 minute trip.
When I was going to hit the button to turn the cruise off, I hit the wrong side and guess what............. The truck idled up to 1100rpm. I was like ...
So either my diablo programed it so that is would work or the dealer programmed it when the previous owner had it.
BUT IT WORKS
Old 08-31-2007 | 04:48 PM
jncornett's Avatar
I followed these same instructions with my 05 st and whata know factory cruise control for less than $40.
elephantrider
01-30-2012 10:58 AM
wmbthe4
05-08-2011 01:19 PM
wreedCTD
01-14-2007 10:22 PM
signature600
23
11-09-2005 02:45 PM
Slice
04-22-2004 08:08 PM
