High idle ??
Old 02-01-2007 | 05:41 AM
HudsonValleyRam's Avatar
High idle ??
Have read numerous posts on here about a "high idle" feature being enabled/disabled. Never heard of this. I did a forum search for "high idle" because my 06 wants to automatically raise idle to 1000 RPM after 2 minutes (about) of sitting at 700 +/- normal RPM. It will go up to 1000 every time you let truck idle, cold,warm or after driving for hours. Is this normal? Is this part of the "fast idle" feature I have read about , or something entirely different?
Old 02-01-2007 | 02:50 PM
GreyTD's Avatar
depending on the ambient temperture (not sure degrees) they all (don't remeber first yr of truck that does, but i'll say 2000 and up) idle up to 1000rpm automatically, even after driving for awhile. The high idle feature that is talked about is the one that you control through the use of the curise control buttons. It idles up to 1100rpm when engaded and you can control it up to 1500rpm, temperature has no effect on this feature, it can be engaded at any time day or night. This feature has to be enabled by the dealer or some programmers will do it to. Also with a stick tranny you need a kit(grd pin?) installed before you can use it.
Old 02-01-2007 | 07:15 PM
yaitsfast's Avatar
Please expand. I have the 1000 RPM high idle that comes on automatically, but was unaware of another feature. Is it in the owners manual? Maybe I should read it hu?
Old 02-01-2007 | 07:24 PM
2005 CTD BEAST's Avatar
If you have an automatic go to the dealer and have them enable the high idle feature so you can use the cruise to use it.
TurboTed's Avatar
You cannot have this enabled on an 03. Only on an 04 or newer.
Old 02-01-2007 | 07:26 PM
I didn't know that.
Old 02-01-2007 | 11:25 PM
Festus's Avatar
You can have it enabled on a manual as well. It just takes a <$20 part from Cummins to get 'r' done.
Old 02-02-2007 | 12:32 AM
Timmer's Avatar
what part is that? the ecm pin, and do you have a part number?
Old 02-02-2007 | 01:02 AM
Festus's Avatar
It's all here: https://www.dieseltruckresource.com/...ight=High+Idle
Old 02-02-2007 | 01:56 AM
Riddler69's Avatar
Idle
Mine only bumps up to 1000 rpm automatically when it is cold(below freezing). It doesn't jump up when the engine is warm. Touching the brake or gas pedal (is it still called a gas pedal in a CTD?) will disable it.
Haven't tried to cruise control method of turning on/off.
Old 02-02-2007 | 06:58 AM
rokspydr's Avatar
It is called "Idle Up" dealer has to enable it.
Old 02-02-2007 | 11:37 AM
GreyTD's Avatar
if you complain to the dealer about poor cab warm up they should be able to look up the proper TSB it. For the 04 and 04.5 trucks the ECM has to be reflashed first then enable. For the 05 and up it's there already and only needs to be enabled.
Riddler69 gas pedal only in gas truck go pedal, skinny pedal, smoke pedal, anything but gas pedal for diesel
Old 02-14-2007 | 07:58 PM
ksram's Avatar
My 03 with high output has the fast idle but only does it on extreme cold days.
Old 02-14-2007 | 08:00 PM
Festus's Avatar
That's OEM from the factory on all of them. The idle being discussed is the one owner controllable through the cruise control buttons - a little more to it with manuals, but doable.
90 power ram
03-15-2011 09:37 AM
kicker210
12-02-2009 08:23 AM
cwrhnr
05-19-2009 05:18 PM
jmccart
06-12-2007 02:12 PM
dieselnewbie
01-18-2005 10:48 PM
Quick Reply: High idle ??
