Hesitation/stutter at 12mph
Old 01-31-2009 | 08:41 PM
efil4ynot's Avatar
Starting last night, I get a hesitation at exactly 12mph (ok, maybe 13) under a light throttle. It's very noticeable in parking lots and such. If I keep it at that speed, the stutter continues. When taking off from a stoplight, the stutter happens just once at 12mph or so and that's it. If I hammer down on it, there is no stutter. It's not enough for it to noticeably drop the rpm's either. Also, it doesn't happen in any other gear, just first.
Everything on the gauges reads just fine. I do still have the original stock lift pump (I know, I know but even w/ Smarty on 8 and my Banks on 6, the fuel pressure doesn't ever get lower than 2psi). Oh, and I just replaced the fuel filter this morning and nothing changed.
So, anyone have any ideas?
Thanks.
Old 02-01-2009 | 09:02 AM
efil4ynot's Avatar
So, I just checked the codes and the only thing I got was p0521 for the oil pressure switch. However, I don't think that would cause the stutter.... right?
Any suggestions?
Old 02-01-2009 | 11:23 AM
BigIron70's Avatar
Cummins Guru
Case Number K13050905
Vehicle Issue Shudder or vibration noted on launch from stop.;Applies to 2003 - 2004 (DR) 1500 / 2500 / 3500 series models equipped with two-piece rear propeller shaft. Shudder from rear axle / rear propeller shaft area may occur on launch from stationary position. Applies to vehicles equipped with two-piece rear propeller shaft.
System or Component Shudder,Vibration;TSB 03-003-04;Customer Concern (No DTCs);Group 03 - Axle / Driveline / Propeller Shaft;Rear;Acceleration,Launch From a Stop
Recommendation Refer to TSB 03-003-04. Subject is launch shudder diagnosis and repair.
Modification Date 01/27/05 5:03 PM
Old 02-01-2009 | 11:26 AM
BigIron70's Avatar
Cummins Guru
Check out this threadhttps://www.dieseltruckresource.com/forums/showthread.php?t=216191
Old 02-01-2009 | 11:44 AM
efil4ynot's Avatar
Thanks for the reply however, this is definitely something w/ the engine.
It feels as if the fuel is being cut to the engine but only at a certain speed.
Old 02-01-2009 | 08:02 PM
BigIron70's Avatar
Cummins Guru
Have one with vibration in shop now, will be changing injectors tomorrow under warranty.
Old 02-02-2009 | 10:39 AM
efil4ynot's Avatar
Hmm.... Is there a way to check the injectors w/o replacing them?
Anyone else have any other ideas?
Old 02-02-2009 | 02:07 PM
Ace's Avatar
Ace
1-2 shift hunt?
Old 02-02-2009 | 02:55 PM
mmurray's Avatar
Just what I was thinking... Common Shuttle shift problem with the 48re.
Old 02-02-2009 | 09:10 PM
efil4ynot's Avatar
Actually, I've got a 47RE. They have the same issue, I assume?
Man, this would be a heck of a stretch to justify a new tranny.
Old 02-03-2009 | 01:24 PM
mmurray's Avatar
I don't think you would need a new one... I know many people have had success with adding an aftermarket (non-Chrysler) Sensor and Solenoid. I will be doing that change on my next service... and maybe more because I have to fix a rear seal leak.
There is also a shift kit many have installed to build stronger line preasure to prevent this shuttle shift issue. My tranny guy told me to just do the sensor and solenoid if I wanted a nice smooth shift, because the shift kit would get rid of the shuttle problem, but because of the increased preasure would result in hard shifts... So it's up to you and what you want.
The Sensor and Solenoid (after market) is less than $100 total and about 20 min of your time.
Old 02-03-2009 | 02:45 PM
04ctd's Avatar
this talks about the OEM solenoid:
https://www.dieseltruckresource.com/...d.php?t=229203
FWIW, i had to cut a peice of plate and put under (above) my carrier bearing, it had a good shudder on take off.
when i was loaded this past weekend, and setting level, it was shuddering again
Old 02-03-2009 | 04:04 PM
efil4ynot's Avatar
Oh, I was just kidding about needing a new tranny. I just really want to be able to mark it off of my wish list.
I found the solenoid/sensor online for pretty cheap so I'll probably give it a shot. I've already got a shift kit in it as well...
However, I'm still not 100% convinced that it's the 1-2 shift hunt from what I've read in other threads. Hopefully I'm wrong.
Old 02-03-2009 | 04:10 PM
efil4ynot's Avatar
Thanks for the link. I haven't seen that one yet.
Old 02-16-2009 | 06:01 AM
efil4ynot's Avatar
For the record, it was indeed the sensor and solenoid. The more I drove it around the more it began to display the same symptoms that other have noted.
Also, I ended up going w/ the heavy duty upgrade found on PATC's website: http://www.transmissioncenter.net/ Shifts just like she's supposed to now.
Thanks again for the help guys.
Quick Reply: Hesitation/stutter at 12mph
