Help! wondering 06 ctd
I ve got a wondering 06 4x4 with 59000mi. Just had new tires put on and had it aligned they said everything was tight and was a little out because it was pulling to the right slightly. It was doing this with old tires as well. Seems to have fixed the rt pull but wonders side to side.
Question is could it be the steering gear box or in the power steering system?
Any info would help
Any info would help
What tires were on it before and what tires did you buy? I had the stock Mich and bought the Hankooks (all stock size). I notice the Hankooks have more of a tendency to wander than the Michelins did. I also had the slight right pull that went away with the new tires. I just think it's the new tires in my case - going from a straight highway tire to an All-Terrain.
Wandering....
Put 1000 miles on the tires and it could go away.
Or lower balljoints could be bad. They will look good when they are lifted and wiggled, but put the weight of the truck on them and any wear will cause binding.
Don't use Moog joints!
lacofdfireman
09-03-2012 11:31 PM
06dodgedrw
05-17-2011 08:10 AM
George C
01-10-2003 07:28 AM
