Help, turbo timer install
Search button disabled. Looked through last 100 days of posts for info could not find which fuses are the ones I am supposed to tap to install my turbo timer.
Thanks for help,
James
Thanks for help,
James
You've got lots of choices... You should just be looking for a constant 12v source, just make sure you don't pick a switched source, or run it right from the batter with an isolator and in-line fuse.
what kind of turb timer you got? mine is a greddy
*****EDITED***** SO YOU DONT HAVE THE HEADACHES I DID...... trying to get info is like pulling teeth!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
RED - 12 v
BLACK - GROUND
BLUE - PINK/WHITE
GREEN - PINK/lt. GREEN
BROWN - BRAKE SWITCH - WHITE/TAN
PURPLE - SPEEDO WIRE - (03 1/2 - 04) - DARK GREEN/YELLOW
(96 - 03) - white/orange
(94 - 95) - white/orange
i have the pin locations if anybody needs them to hook up there own......
RED - 12 v
BLACK - GROUND
BLUE - PINK/WHITE
My fault, I bought it for my 98 a year ago, I threw the directions away. No directions on his web page, and he hasn't answered the email I sent him.
If you are still looking for the info here is what I have:
Red: wire needs to be powered by a fuse that is at leas 20A and is hot at all times
Blue (2004 Dodge) Fuse #53 (engine compartment) #28 or #50 can be used.
Green wire to ground unless you want parking brake shut off
Hope this helps
Mishkaya
Hope this helps
Mishkaya
Hope this helps
Mishkaya
Hope this helps
Mishkaya
James
Mishkaya,
Do you have a 600 engine? on mine #53 fuse a 15a air bag, 28 is gauge cluster, and 50 is trans relay. I think I am back to square one.
Thank you anyhow,
James
Thank you anyhow,
James
If you don't want to deal with fuse taps you can tie into the Pink/Green wire under the dash for the ignition wire, and the large Red wire under the dash for constant 12v.
There is a chance you will throw a P0480 and/or P0243 code when you hook it up this way. If you do, you need to install a jumper from the Pink/Green wire to one of the Pink/Yellow wires under the dash. I'm not positive which Pink/Yellow wire, but it is one of the smaller ones.
Have fun
Have fun
procrastinator
No, I don't have a 600 engine, 2nd gen for me. I was just quoting the instructions I have for the timer (purchased last fall) for your model year. According to said instructions, you are fine with any of those fuses. I personally used a painless wiring kit, to make sure I didn't interfere with anything. The reasoning behind using the fuses indicated is that they need to be at least 20A and I don't think you need to worry about needing the airbags, if the timer is functioning!
Good luck with your install
Mishkaya
Mishkaya
Have fun
Have fun
I had a PITA time getting my turbo timer in w/o throwing codes and the check engine light. After reading hours of wiring diagrams, taping wires, and trying different things, I finally got the CEL out and the timer working good. I found this post by searching the P0243 code which I have left over from the first go around with only having the timer hooked up using one wire( 16ga Pink/Green).
So I'm searching the code and I find the EXACT wires I used to finalize my install. THIS would have saved me many hours!!!
Anyway, on my 04.5, here's what I did... The short version anyway LOL!!
~ Opened the hatch right under the steering column
~ located the bundle of wires coming right out of the driver side of the column..
~ Soldered into one of the heavy 10ga red wires for constant 12v high current source. I also added a fuse from here to the timer..
~ Soldered the timer ign. lead into the small 16ga Pink/green stripe wire..
~ soldered the timer accy. lead into the 16ga pink/yellow stripe wire. BE CAREFULL, THERE IS A 14GA PINK YELLOW! FIND THE SMALLER ONE!!
~ ground under the dash..
~ Tape the timer right to the left of the column..
~ DONE! Works great!!
Here's the Apexi timer I got...
Apexi turbo timer
Don
06RAMCTD
11-06-2009 11:35 AM
CTDPower11
01-23-2007 09:29 AM
TripleBquad
13
11-20-2006 02:59 PM
