Help!! Transmission does not gets out of 1st gear unless..
Old 10-17-2009, 06:23 PM
delviacv2's Avatar
hello everyone, My dad has a problem with his 2006 Ram 5.9L it has around 75K miles and is a auto.
here is the problem:
when he takes off the truck does not gets out of first gear unless he takes his foot off the gas pedal or unless he is very gentle(drive really slow).
I have searched here bunch of times looking for a solution and apparently found the solution "governor pressure solenoid" so I send him this part(the truck is in dominican republic) a transmission shop replaced the solenoid and the problem still there so the governor pressure solenoid was not the problem
anybody had this problem before or has an idea of what could be?
thanks in advance.
Delvi Acevedo
Old 10-18-2009, 07:34 PM
delviacv2's Avatar
anybody?
Old 10-18-2009, 08:08 PM
Torqfan84's Avatar
did they try a 1-2 band adjustment while the pan was off?
1985cucv's Avatar
band not adjusted properly trans is prolly junk have to get the thing replaced or if your lucky you might just be able to adjust it. look for band adjustment on here i know it is in here somewhere
Old 10-18-2009, 08:24 PM
Just a plain ole guy
1-2-3's Avatar
A band broke in my 99 and I had this exact symptom.
Old 10-18-2009, 08:40 PM
delviacv2's Avatar
I'm pretty sure that they have not try that yet, I will do some search and tell them what to do, thank for the help, I will keep you guys up to date.
Delvi.
Old 10-18-2009, 09:01 PM
drdodge's Avatar
check for any code(s)
Delvi I'm also in the Dominican Republic, did you check codes with the three key
trick.???
If is the governor pressure switch you should a code and the check light on. I had mine with code 1756 and i`m working on it.
Old 10-18-2009, 09:11 PM
delviacv2's Avatar
trick.???
Hello, I'm here in us, my dad is over there with the truck, I don't think they have checked for codes but according to him there is no check engine light.
I sent him the governor pressure solenoid and they replaced but problem still there, so I will so some search tomorrow on the band adjustment and I will get them to do it and see what happens after that.
Delvi.
Old 10-19-2009, 02:57 PM
RoadDawg's Avatar
trick.???
How do you do the 3 key trick?? I am having this same problem..
Old 10-19-2009, 10:05 PM
drdodge's Avatar
checking codes
flip key on and off within 10 sec on each cycle, that will display code(s) on the odometer display...
That`s the key trick!!!
Old 10-19-2009, 10:41 PM
Dr.Dizzle's Avatar
The following link contains step by step instruction regarding the key trick. This informative presentation was put together and posted by DTR member Madhat.
https://www.dieseltruckresource.com/...s-t224833.html
Old 10-20-2009, 11:09 AM
RoadDawg's Avatar
Ok I checked error codes and found none. I took the truck to a local Tranny shop and he scanned it. He told me the tranny is ok that when the trailer (lights) is hooked up it is sending a power feed back that is causing the problem. So I'm going to hook the boat up w/o trailer lights and see what happens.
Old 10-21-2009, 04:18 PM
delviacv2's Avatar
Band adjustment
Update:.......
they just finish the band adjustment and they say that overall it shift a lot better but the problem still there.
So since they already replaced the governor solenoid I quess the transducer is next.
http://www.transmissionpartsusa.com/...-00053397a.htm
Delvi.
Old 10-21-2009, 05:47 PM
RoadDawg's Avatar
Ok the tranny shop said 2nd gear is shot. He going to take it apart tomorrow. I keep everything posted.
Old 10-21-2009, 09:23 PM
delviacv2's Avatar
Codes
ok I got my father to read the codes with the key trick
this is what it came up:
-no P codes
and
C447
S113
'264
does anybody knows what they are?
I search and only found all the P codes
Quick Reply: Help!! Transmission does not gets out of 1st gear unless..
