Help!!!!!! Trannys Broke!!!!
Old 08-23-2011 | 11:49 PM
oberon1974's Avatar
Exclamation Help!!!!!! Trannys Broke!!!!
So........ I got into my truck, started it up, let it warm up for a bit, put it in drive, stepped on the gas a little, and started to pull away when...... it just gave up forward motion altogether. I have never felt it slip or shudder in its life except for the standard governor solenoid prob. I was able to creep it out of the way by turning off the engine, waiting a twenty count, restarting, and feathering the throttle for 5 - 10 feet of progress!! I had to do this at least forty times to nurse it into a parking spot!!! I dropped the pan, changed filter and fluid, started it up and drove a half mile or so and then bang, same **** thing. so i did the same on/off dance to get it parked again. Then i changed filter, gov solenoid, fluid, and cleaned and checked entire valve body. Bolted it back together and now i have reverse but no forward movement at all. doesnt even catch when you shift it into drive. Truck and tranny are mildly modified; ie. bully dog, exhaust, airaid, triple disc, billet shaft, trans valve body modified, etc. been running same combo for long time with no prob. What is going on? is it the torque converter? And if so why do i have reverse? PLEASE HELP!
smokeum99ta
12-08-2017 01:32 AM
Jones0027
01-28-2003 11:01 AM
ROCKNRAM
10-13-2002 02:53 PM
Quick Reply: Help!!!!!! Trannys Broke!!!!
