Help-tach not working right
When sitting still my tach reads about 100 rpm. Sometimes a little higher. What is the idle supposed to be? It used to read a little over 1000 rpm.
I had issues with the tach jumping around at idle between 400rpm-750rpm. My truck kept popping camshaft sensor signal codes everyday. I replaced the sensor and when I did I realized the TST wire harness that plugs into the cam sensor wasn't fully locked. The orange tab was not fully engaged in the connector. It took a while but I finally got it engaged and the rpms on the tach are dead set on 700 rpms all the time at idle.
Sleigher
05-04-2017 02:12 PM
Michigan Ram
08-24-2011 11:25 PM
emw911
04-05-2010 01:05 PM
scoutman
11-30-2007 02:56 PM
