Help with 04' making alot of racket...
Hi guys, my 04' went from a slight ticking sound to knock,knock,knock,etc...to bam, bam, bam,...the knocking to bamming was approx 1 minute, so I shut it off. It also had the ticking ever since I got it back from the diesel shop to get new injectors and pump. The knocking and bamming came out of no-where... It had a bunch of blow-by after it started making the noise as well. So I think it blew a piston or something because the diesel shop I just happened to coast into said it was probably because of the Edge box I had and that it was known for overfueling. So now the head is off and everything looks good. I am at a loss....was it just an overfueled cylinder that made the sounds that shook the floor of my truck? Any help would be appreciated...at least I now know I can pull the top end apart pretty easy..thanks, Scott
haven't pulled the pan yet, was hoping it may be an injector...there was no popping, sounded more like a bearing that went bad and then went worse. I will pull pan today to get a better idea I guess...thanks
BMH95
07-25-2011 08:18 AM
Cummins600
06-03-2005 08:28 AM
