Has anyone fixed there hard start issue
The hard starting that we are talking about, is that the engine cranks fine, but has to crank a long time before it starts running.
As far as the dealer... They have a procedure to check the back flow (return fuel flow). If the total value is to high, then it can be isolated one place at a time. i.e. each injector, and the relief valve.
Paul
Paul
I may have the same issue. If i don't turn the key on and wait about 30 seconds for the lift pump to turn off. It is a GDP lift pump mine will just crank and crank and may start may not till i recycle and wait. When it does start it puffs lot of black smoke? Is this an indiciation of the injectors going bad? Also when the truck is warmed up it now has a haze at idle. The haze is so bad at time is almost looks like an over fuled pulling truck. I have only noticied since putting the stacks on the truck but it has done more sitting than driveing this year.
I had the same hot start issues as many others with an 03. Spent many hours searching posts and trying other peoples fixes. Finally bit the bullet and replaced the injectors with 50 hp injectors from Dynamite Diesel. No more hot start problem. It's been 3 months now. I also upgraded the fuel filter system with a 2 micron filter. I would highly recommend this to prolong the life of the new injectors.
I have had problems with my 2003 so finally changed the injectors and its like new again. The only bad part is my wallet is empty!!!! 145,000 miles . Winter is on its way and allways had to plug it in to start. I will let you know if that is gone also.
Spoke with a guy that runs an injector shop and has been dealing with it for years. They are only seeing them last about 150k to 200k miles and about 350k on over the road trucks. He suspects as many times as they fire these injectors for emmission componets it is shorting their lives. In 2003 there is 2-3 injector event and they are just wearing out.
Mine was intermittent at first and got progressivly worst. The 05 are supposed to be better but some folks say it is all of them. I see you have smarty if you are using the rail pressure setting it could be straining them and wearing them out. My guess if not something electical then they are staring to wear. When my rebuilds get in it will have 2 micron filter after the factory filter and it will have a lubricating aditive in every tank from now on.
What additive yo gonna use? I have been throwing around the idea off adding a little bit of oil or mystery oil with each tank. I have heard of people using trans fluid too. If I could find a place close enough I will get a bunch of bio and add each some each tank. But that won't happen any time in the even the far off future. Because some of those additives are pricey as heell
Now that I have the new injectors in I have been using Stanadyne. Hopefully this will protect them a little better. I used to use Power Service and will when I can't get my hands on the Stanadyne.
I tell you what though, she fires right up with the new ones in. Knock on wood!!!
Stanadyne, power service are all good choices. The place that is doing the work for me has one he recommends but the name of it escapes me. Yep they cost a little but at 300-500 a piece for brand new it believe it is cheap insurance. Plus my truck now sits more than it is driven so I think it will be well worth it in my situation.
I have an 05' with 68k miles on it. Is the hard starting issue you are talking about occasional and to describe it sometimes it just does not want to turn over when starting it almost sounds like trying to start a flooded engine. Those are the symptoms which mine is exhibiting.
And if that is the case how could I get the retards at the dealership *********** to correctly diagnose this before my 70k mile warranty is up.
Thanks
