hard shifting 48re
Old 01-25-2005 | 12:50 PM
052500#1's Avatar
hard shifting 48re
When I first got my truck it shifted very nice. Then I put the 305/70/17 mtr's on and then it started shifting ruff. Took it to my local dealer and they suggested that I re program the truck for the bigger tires. Seemed like it helped. Although now it is shifting ruff again. 1st to 2nd is the worse. Any ideas?
Old 01-26-2005 | 04:42 AM
Dodgezilla's Avatar
Try resetting the APPS. Go to the FAQ section to find out the procedure...
Old 01-26-2005 | 06:10 AM
Hondo's Avatar
I'll bite, what is the APPS? Just a silly newbie question.
Hondo
Old 01-26-2005 | 12:14 PM
052500#1's Avatar
I went to the FAQ section and did not find anything about reseting the APPS? What is the APPS?
Thanks
Old 01-26-2005 | 02:04 PM
K2Cummins's Avatar
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old 01-26-2005 | 02:22 PM
Dodgezilla's Avatar
Accelerator Pedal Position Sensor
I meant Tech Facts section....... Sorry
Old 01-26-2005 | 03:27 PM
052500#1's Avatar
This applys to 24 Valve ISB - 2nd Gen - Engine and Drivetrain : APPS Reset Procedure. Will this apply to 3rd gen 48re?
Old 01-26-2005 | 04:42 PM
K2Cummins's Avatar
Pretty sure it applies to both.
Old 01-27-2005 | 03:01 PM
scott hall's Avatar
Mine is a 05 4x4 W/3.73 gears and it will sometimes break the tires loose on the 1-2 shift , I know that sounds a little on the windy side but it's true, besides I like a hard shifting tranny, a carry over from my racing days I guess.
Old 01-27-2005 | 05:39 PM
Dodgezilla's Avatar
Actually, can you explain "Ruff shifting" to us?
Old 01-28-2005 | 01:04 PM
052500#1's Avatar
It seems as if the shift is normal. I test drove another 2500 with the 48re last night and it shifts out the same. This is my first truck with this much torque. I guess a hard shift is a good shift when dealing with this much power.
Do your 315 Bfg's rub ?
Thanks for your thoughts!
Old 01-29-2005 | 05:20 AM
Dodgezilla's Avatar
Mine only rub at full lock if I hit a bump. Like when I turn into my driveway and I hit that dip. It's so minimal there has been no damage to the tire or the truck. It doesn't bother me....
A firm shift is good. A hard shift may not be...
Old 01-31-2005 | 06:28 PM
money_d's Avatar
Hey i have 22,000 miles on my high output and my shifting is a little rough from third to overdrive. its seems like the trucks shifts out of 3rd, then back to 3rd and then finally into overdrive. Any suggestions?
Old 02-02-2005 | 12:36 PM
052500#1's Avatar
When I say hard shift i mean it gives the truck quite a jolt shifting from 1st to second. I can feal the first shift alot more than the rest. Is this normal?
Brendan
10-17-2007 11:12 AM
98 Ram 24V
12-24-2005 10:19 AM
bigtobe
10-28-2003 03:19 PM
dansdad
09-06-2003 09:00 PM
courtndd
05-29-2003 05:07 PM
Quick Reply: hard shifting 48re
