had oil changed
As for letting it sit, I only noticed a major difference between immediately shutting down and checking and letting it sit for about 5-10 minutes and checking. After about 5-10min the level seemed to be about the same as it would be after 12-24hrs. When I checked immediately following shutdown it only read about half full according to the dipstick.
alright i bought 3 new gallons of 15w 40 rotella t. im gonna open the drain plug and let all the oil drain out then refill. how much should i put in, 11qts?
im not gonna change the filter since it was just changed.
i figure be safe than sorry, and get to know my truck a little.
Lots of guys never prefill their filter and have never had a problem. I just hate to see a guy dump all that oil if there is nothing wrong with it other than having too much in the pan.
-Chuck
-Chuck
i also noticed the guy at the shop having to wipe the underside of the truck down because oil spilled when he took my old filter out, any tips to prevent this from happening and keeping the truck clean?
-Chuck
Be careful. I know guys who do it all day long and never spill off the filter. But, mistakes happen. At least he cleaned it up!
For the drain valve, I can't remember the name. I picked it up at my local Cummins Engine shop. It is a nice little unit that replaces the drain plug. It is all sealed and well made. To drain the oil, you remove the brass o-ring sealed cap from it. No oil comes out at all. Then you take the adaptor fitting and thread it on where the cap was. As this fitting with a tube on it is threaded on, it pushes up the internal valve, which allows the oil to drain. It is clean as heck. You never get a drop on your hands, and it requires no tools, just your hands. When done, you remove the drain adapter, put the cap back on, use a paper towel to wipe up the drain tube adaptor, and throw the drain tube adaptor back in the glove box.
I scared a friend recently who was looking at it. I reached over and spun the cap off the oil drain, and he was surprised when nothing came out. It is a safe setup, and so far I've been real pleased with it. I don't like simple valves like petcock valves under there, because it is too easy for a branch or vandal to flip the valve and drain the oil without me knowing. The system that I have is real easy to use, but requires that extra adaptor to make the oil come out. So even if you take the sealed cap off the drain plug, no oil loss occurs.
-chuck
-chuck
