Guys with FP gauges - how fast are your filters clogging?
Re: Guys with FP gauges - how fast are your filters clogging?
Originally posted by Lightman
Hey guys. I'm curious- those of you that have fuel pressure gauges, how many miles do you go before you start pulling down to 3-0 psi during medium to low acceleration? I was previously changing my fuel filters every 10,000 miles, but since I've installed the gauge, it seems like after 5,000 miles or so the filter starts getting restricted. When I throw a fresh filter in, I typically get 7.5psi at idle, and around 6-6.5 at cruise. It barely drops below 5psi during normal and mildly aggressive driving. When I have the box turned up, I have to have it in 100hp mode and stomp it pretty well to pull the pressure down to 0psi. After about 5k if I have the box turned up at all I can hit 0 really easily. That makes me wonder how some guys go 30-40k between changes. I may do a fuel analysis test just to be sure my station isn't serving up extra dirty fuel that's prematurely clogging my filters, but I doubt it. The guys that own/run this station are very interested in diesel fuel and fuel quality, and love to talk about it. Any info appreciated!
Coob, I'm familiar with the fass system and am not interested, no offense. I'll be going with a nice and quiet RASP when I upgrade. However, the issue here is not low fuel pressure. I'm trying to determine the stock lift pump's pressure trends as mileage accrues, so I can see if my readings or normal or if I may have a dirty fuel source. Now that most people with my configuration have reported far less drop compared to my experiences, I will probably do a fuel analysis of my station. When I did this a few years ago in Florida, one of my local stations had SEVEN TIMES more particles per gallon than another local station. (both were high volume stations with truck islands - fresh fuel doesn't always=good fuel, just fresh ). In any case, with the increasing injection pressures today and especially with a pressure box, I want the cleanest fuel I can get.
Coob, I'm sure the fass pump is a great system. I hadn't heard about the larger pickup tube, but I just happen to have some super sensitive hearing, and any additional tiny noise tends to drive me nuts.
Guest
Posts: n/a
Do you have a parts list or location that sold you the big tube kit for the 3 Gen FASS setup? I am very interested in doing this to my truck. For some reason I do not think I am getting the flow I should from the FASS and want to eliminate the possibility of it being the stock tube assembly. Thanks for any info.
"1sttruck, just curious, but why do you think low fuel pressure would cause the filters to clog earlier?"
Filters are ideally changed when the pressure drop across the filter reaches some value, say 5 psi, but for those of us without fuel pressure gages we will change them when recommended, 15k miles, or when we notice a lack a hint of stalling at cruising speed, lack of acceleration, or a rough idle. I've never been able to get more than about 8k miles out of a filter before getting such symptoms, so I'm guessing it's low fuel pressure. A pressure drop across the fuel filter combined with low fuel pressure to begin with will produce shorter filter life.
MossyOakGlock
11-15-2007 01:44 PM
kopfjaeger
05-03-2007 09:43 PM
Intercooler
17
06-06-2005 02:11 PM
