Grinding Feel in Gas Pedal
Hello,
I have a grinding feel in my gas pedal when the engine warms up. It only occurs shifting from first to second in my 48re transmission. Anyone else experienced this?
Thanks
Thanks
What year is your truck? Maybe its a 6 speed thing BUT cruise etc on auto/6 speed(can't rember which)is cable and a pivot etc.under d/side battery.It moves with gas pedal.In fact a TSB about a rubbing problem if I'm not mistaken! Look at TSB'S.FILL OUT YOU SIG.With year/model/equipment etc.
Originally Posted by dogeman53
Hello,
Thanks
Thanks
Either way, they are all "drive by wire" even if its mounted on the engine. You probably have a corroded TPS cable or a corroded TV Cable (trans kickdown).
Originally Posted by bigblock2stroke
If you really have an 04.5MY, the TPS is still mounted on the engine like the 03's. It wasn't until 2005MY that they went to the TPS located on the pedal for the autos, because they couldn't figure out how to activate the TV cable on the transmission.
Thanks,
DM
Hello,
Thanks
Thanks
Are you going to take it to the dealer for warranty?
Originally Posted by TexasCTD
I have noticed that on mine too, but really didn't pay it much attention. I just thought it was part of the "personality" of my truck. Mine is also an 04.5 with the 48re.
I had them check it when I did the window binding fix. They could not replicate. I will take it in on my next change and make sure the engine is warm and it is occurring.
DM
Hello,
Thanks
Thanks
600 Megawatts
03-26-2008 08:09 PM
nelrod
01-20-2007 06:52 PM
cLAYH
02-06-2004 11:59 AM
