Grid heaters
Old 09-17-2007 | 07:57 AM
chamisi's Avatar
Grid heaters
are these expensive,how long do they last vs.glow plugs? thanks
Old 09-17-2007 | 12:22 PM
SSminnow's Avatar
Never heard of one going out if that helps you.
Old 09-17-2007 | 12:32 PM
13FOX's Avatar
Same here. Dad just sold his 94' 3500 dually 10 months ago. Had 400,000+ miles and only replaced the clutch. No grid heater failure and never heard of one.
Old 09-18-2007 | 03:41 AM
DREDnot's Avatar
Mine doesn't even have wires hooked up to it!
I was thinking of getting a glacier block and intake elbow to remove the restrictions
Old 09-19-2007 | 09:49 PM
md-rebel's Avatar
OK mine isn't hooked up either, does this mean the grid heaters aren't hooked up??
Old 09-19-2007 | 10:22 PM
SjLingenfelter's Avatar
there is no wires on the other side?
Old 09-19-2007 | 10:59 PM
InfernoB's Avatar
The connection is not complete. There is no ground. The B+ wires are on the other side.
Old 09-20-2007 | 12:27 AM
Danavilla's Avatar
They ground through the housing. They all look like that.
Dan
Old 09-20-2007 | 08:24 AM
InfernoB's Avatar
My solenoid works when cold enough, but the heater does not get warm. I checked with a meter, but no continuity on the side of the photo shown.
I will recheck when the weather is cold enough.
In my experience with the grid heaters on 6BTA marine engines......there is a buss between those studs on 12V system, and a ground wire. There are also two solenoids as the system cycles both grids. I have not really sat down and studied the electrics of this system. The drawing in the '07 book shows a ground. I will check and see if there is resistance today between the stud and case of the heater.
I hope I am not hijacking this thread.....
Thanks.
Old 09-20-2007 | 10:54 AM
DREDnot's Avatar
Once I climbed up on top of the engine I could look down and see the cable hooked up to the other side. Traced that back to the pass side to the solenoid
Old 09-20-2007 | 11:06 AM
md-rebel's Avatar
X2 It's wired.
Old 09-20-2007 | 06:58 PM
InfernoB's Avatar
Danavilla is correct. The connection is complete through the housing. When it is cold enough here I will recheck. Since I first checked this I had the grid heater lose to install my boost connection in the intake elbow. I also noticed lots of clear paint on everything.
This system also only uses one solenoid for the heater. There is a B+ wire from the solenoid to the heater, which is bussed to both posts on the side you can't see in the above photos.
Good day when I learn something. Thanks.
Old 09-20-2007 | 07:10 PM
Nate-03 D's Avatar
When buying the GDP intake horn they offer a grid heater for a little extra. Does the GDP horn it's self eliminate our stock one, hence the reason why we have to buy their heater to actually have one?
Old 09-20-2007 | 07:14 PM
rustyshakelford's Avatar
you can get the grid heater deletes...
brett
Old 09-20-2007 | 07:48 PM
Nate-03 D's Avatar
ok, but when it's -20* here what is going to heat up my incomming air? If it's on the truck now and i'll need it in the winter i'd like to keep it on there. So you can't run a aftermarket intake horn and still keep your grid heater?
Quick Reply: Grid heaters
