Governor Pressure Solenoid questions
I have an 06 Mega Cab and my Governor Pressure Solenoid is acting up every now and then. (tranny hunts between 1st and 2nd at low throttle) The question I have is.....will this part leave you stranded or is it just something that is annoying ? I have a long trip at the end of the month, and I don't know if I will be able to get it fixed by then.
Also, does anyone know the part numbers to fix this ? How expensive is it ?
I have an extended powertrain warranty with a $100 deductible. If I can easily do it myself for $150, I will probably do that, as opposed to leaving the truck at the dealer for the day.
Dodge wants $120 for it, heres the cheapest place I found to buy it from http://www.trademotion.com/partlocat...&siteid=214583
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of DaimlerChrysler Corporation.
SUBJECT:
48RE Transmission - 1-2 Shift Hunt At Light Throttle
OVERVIEW:
This bulletin involves the replacement of the governor pressure solenoid valve in the
transmission valve body.
MODELS:
2004 - 2007 (DR/DH/D1) Ram Truck (2500/3500)
SYMPTOM/CONDITION:
The customer may experience a 1-2 shift transmission hunt during light throttle application.
This condition may be due to a governor pressure solenoid valve.
DIAGNOSIS:
If the customer experiences the above condition perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 04617210 Valve, Governor Pressure Solenoid
4 05013457AA ATF+4 Automatic Transmission Fluid
AR 02464324AC Gasket, Transmission Oil Pan (Note: Original pan
gasket is reusable and should not require
replacement).
REPAIR PROCEDURE:
1. Raise the vehicle on a suitable lift. Turn the ignition switch to the “OFF” position.
Remove the ignition key from the ignition switch.
2. Remove the transmission fluid (oil) pan and pan gasket. Clean and save the pan
gasket for later use during reassembly.
3. Disengage the wire connector to the governor pressure solenoid valve (Fig. 1).
4. Remove the screws used to secure the governor pressure solenoid valve retainer to
the transmission valve body.
5. Remove the old governor pressure solenoid valve from the transmission valve body.
6. Clean the transmission housing and oil pan gasket surfaces.
7. Lubricate the o-rings on the new governor pressure solenoid valve.
8. Align the governor pressure solenoid valve to the bore in the valve body.
9. Install the governor pressure solenoid valve to the valve body.
NUMBER: 21-009-07
GROUP: Transmission
DATE: May 24, 2007
10. Install the governor pressure solenoid valve retainer and attaching screws to the valve
body.
11. Connect the wire connector to the governor pressure solenoid valve.
12. Install the transmission fluid (oil) pan and pan gasket (saved earlier) to the
transmission. Tighten attaching bolts to 13.6 Nm (125 in. lbs.).
Fig. 1 Governor Solenoid And Pressure Sensor
1 - GOVERNOR PRESSURE SENSOR
2 - GOVERNOR PRESSURE SOLENOID VALVE
3 - ELECTRONIC GOVERNOR
13. Lower vehicle.
14. Add automatic transmission fluid to the transmission.
15. Verify correct transmission fluid level.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No: Description Amount
21-96-05-90 Valve, Transmission Governor
Pressure Solenoid - Replace (B)
0.7 Hrs.
FAILURE CODE:
ZZ Service Action
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
PARTS REQUIRED:
replacement).
REPAIR PROCEDURE:
NUMBER: 21-009-07
GROUP: Transmission
DATE: May 24, 2007
body.
13. Lower vehicle.
POLICY:
TIME ALLOWANCE:
0.7 Hrs.
FAILURE CODE:
ZZ Service Action
I have an 06 mega and they fixed it for free. Now I have only 10K miles and have the extended chrysler also. I don't think it will leave you stranded but it could get worse. The silenoid just isn't working correctly so unless you are at speed that is 1st or 2nd gear all the time you wouldn't notice it. Also you get a free transmission service while they're in there as the TSB says to replace the ATF. I had them clean the filter too.
Kevin Krieger
03-28-2009 07:08 PM
bigfish5
11-17-2008 01:41 PM
KillerBee
12-27-2007 10:45 PM
Mopard
18
11-29-2007 07:10 AM
airplaneman00
08-04-2005 09:37 PM
