got a used ecm,do i need a reflash for my truck
Old 03-04-2010 | 12:01 PM
no_6_oh_no's Avatar
Originally Posted by danimal 95
i guess i dont really understand what you mean???why couldnt i drive it to the dealer and put the new ecm in there??and why couldnt they flash the ecm with my vin andd updated file???and what do you mean they cant fix it?
It AFAIK, dealers can only update existing code base or flash a blank ECU, they don't seem to be able to take an already loaded ECU and flash it for a different truck.
Old 03-04-2010 | 12:08 PM
danimal 95's Avatar
what in the hell is AFAIK?
Old 03-04-2010 | 12:09 PM
danimal 95's Avatar
Originally Posted by cLAYH
On my '03 with the Sentry system(grey key) the vin for the engine ECM is programmed into the truck's BCM computer. If you swap the computer the codes won't match and the BCM will thro a security code and not aollow the engine to run.
In my case I sawpped in a used motor that came with its own ECM. I just left it on when I swapped the motor in. Upon trying to start it the engine would fire then die and the little red secruity light on the dash would blink. Swapping in the original ECM off of the removed motor solved the problem and the truck fired up. I don't know if this would effect a non-sentry equipped truck or not. Try it and let us know.
Worst case scenario if it doesn't work I don't see why you couldn't take the truck to a dealer and have them install the computer and re-program the BCM to accept it.
Whats wrong with the truck anyway that you want to swap ECMs?
here is the list of problems,started in the HELP section
https://www.dieseltruckresource.com/...t-t264602.html
Old 03-04-2010 | 03:07 PM
no_6_oh_no's Avatar
LOL, As far As I Know.
Something did not edit right on that line.
Old 03-04-2010 | 05:36 PM
danimal 95's Avatar
the ecm showed up today,i out it in and as stated it starts then diesso is there anyway to get my security code installed in this ecm?or do i have to send it out and have a new program installed?
Old 03-12-2010 | 05:45 PM
cLAYH's Avatar
Thats what mine did. The only suggestion I have I to tow it to the nearest dealer and have it programed. I don't think it can be done out of the truck.
Old 03-12-2010 | 05:47 PM
cLAYH's Avatar
To save the tow charge you could put the original ECM back in, limp it over to the dealer and then put the new ECM in and have them program it.
Old 03-12-2010 | 06:05 PM
no_6_oh_no's Avatar
..and after they can't get it to run he can either have it towed home or again change the ECU back the correct one to get the truck to run. If you find a dealer that can reflash for VIN change, post it up so the rest of us can send our ECU's to them and have it done. NONE to this point have proven to me they can do it and everyone I asked said NOPE.
mr. ed
05-06-2009 07:20 PM
Derek Roch
11-08-2007 12:11 PM
SBRW
07-30-2006 06:43 AM
Diesel-Dan
07-15-2005 10:13 AM
Quick Reply: got a used ecm,do i need a reflash for my truck
