Gold color leak, evaporates after a few days?????
Old 03-07-2010 | 06:36 PM
dieselfamily's Avatar
I revcently bought a 2006 3500, 5.9l 4x4. I've found where I think this leak is originating from, unsure where to go from here. Looking up under the truck on the passenger side, it's leaking from the flex hose connecting two pipes. This is above the oil pan, toward the rear of the engine block. Are these tranny cooler lines? If I remove the flex hose will it rain fluid down on me? Has anyone else had this problem?
Anything will help!!
Des
Old 03-07-2010 | 06:50 PM
Lost Lake's Avatar
Yep, one of the most common problems with our trucks. If you'd like, you could search and find hundreds of posts about the issue.
I tightened my hose clamp last year and it hasn't leaked since. There is a new hose and clamp available... Better hose, and a spring clamp instead of a worm clamp.
Welcome to the site!
Old 03-07-2010 | 06:55 PM
Awesome! Thanks for the quick response! So, I'll tighten the hose clamp, now where should I replace the lost fluid? Might be totally obvious, but new to these diesel engines and big trucks etc.
Thanks again.
Des
Old 03-07-2010 | 06:59 PM
Lost Lake's Avatar
It's a coolant line, I'd put it in the overflow tank. Probably don't have enough missing to worry about.
Old 03-07-2010 | 09:32 PM
papaduck's Avatar
Just make sure the coolant is HOAT. Don't mix HOAT with DEX coolant.
You probably have Zerox GO-5 which is light gold in color. MOPAR coolant is pink.
swed
10-04-2011 09:09 PM
boaterman
10-15-2008 10:44 AM
salmon
08-08-2008 07:19 PM
TIMMY22
27
07-12-2006 09:23 AM
mt72916
02-01-2005 08:00 AM
Quick Reply: Gold color leak, evaporates after a few days?????
