Gears mashing when putting it 4wd or low range
Old 12-10-2008 | 11:39 AM
2003Ram's Avatar
This is in my '03 <service> manual -
SHIFTING
The transfer case can be shifted between the 2H
and 4H operating ranges while the vehicle is in
motion. The vehicle must have the transmission
placed in NEUTRAL, or the clutch depressed in the
case of a manual transmission, and be moving less
than 2-3 MPH when shifting into and out of the 4L
operating range.
Transfer Case noisy in all operating
ranges.
1) Insufficient or incorrect lubricant. 1) Drain and refill to edge of fill hole
with MoparT ATF +4, Automatic
Transmission fluid.
Noisy in, or jumps out of, four wheel
drive low range.
1) Transfer case not completely
engaged in 4L position.
1) With the transmission in
in the case of a manual
transmission and the vehicle moving
under 3-4 km/h (2-3 mph), shift the
transfer case to NEUTRAL and then
shift into the 4L position.
2) Shift linkage out of adjustment. 2) Adjust linkage.
3) Shift linkage loose or binding. 3) Tighten, lubricate, or repair
linkage as necessary.
4) Range fork damaged, inserts
worn, or fork is binding on the shift
rail.
4) Disassemble unit and repair as
necessary.
5) Low range gear worn or
damaged.
5) Disassemble unit and repair as
necessary.
Old 12-11-2008 | 06:15 AM
05HDRAM's Avatar
I mistated what iis in the manual for my '05. 2-3mph going into and out of 4lo. If there is a pause at the Nuetral position, it may cause grinding or not go into gear. If that happens, shut down and then shift out of or into 4lo.
Bill M.
19
12-21-2010 06:28 PM
OrangeBlackHD
06-22-2010 07:11 PM
Landini1
15
11-25-2008 04:29 PM
Mark Hodowanec
03-19-2007 05:55 PM
93beater
02-28-2007 09:28 AM
Quick Reply: Gears mashing when putting it 4wd or low range
