Gear shift label turning
My shift pattern label on the top of the gearshif for my 6 speed has turned about 90 degrees. Just cosmetic, but has anyone had the same problem and how do you turn it?
Re:Gear shift label turning
Yea they spin. It's the plastic gizzmo that has the shift pattern on it. Three options. 1. take it to the dealer, loose the truck for a day and they wil put it on straight, then it will start to rotate again. 2. take a very smal kinfe and pop it off, glue it on in the position you want and problem solved. Or 3, let it go. You know where the gears are I assume, so forget it.
2 cents.
2 cents.
I think I will go for option 3. Ive tried to pry it off but was afraid I would mess up the rubber around it. I think I know where the gears are?
Thanks
Thanks
Read the recent long thread on this. Last week? Or was it the week before? Time flies when you are having fun - reading DTR stuff.
[quote author=bulabula link=board=20;threadid=18515;start=0#msg173839 date=1061214426]
Nope, not too much discussion on this topic. But if you're interested, click here. Last I looked it almost had a thousand views.
[/quote]
bulabula, a thousand views ??? Bet you have been told a million times not to exagerate
[/quote]
[quote author=Mexstan link=board=20;threadid=18515;start=0#msg173852 date=1061216503]bulabula, a thousand views ??? Bet you have been told a million times not to exagerate
[/quote]981; close enuf for govt work.
On edit: Ooops, now its 985.
95yukon
12-28-2007 04:36 PM
