Gear Box Issue
Old 05-23-2012 | 09:10 PM
BigIron70's Avatar
Cummins Guru
Gear Box Issue
Has anyone had this happen to them yet? I hope not, you should think about upgraded to the larger gear box with bigger diameter pitman arm and inner tie rod if you own a lifted truck and it is 4X4. No warning when it breaks but complete loss of steering.
Old 05-23-2012 | 09:32 PM
rockcrawler304's Avatar
That sucks! You can tell it has been cracked for a while by the rust.
How fast were you going when it broke??
Old 05-23-2012 | 10:23 PM
BigIron70's Avatar
Cummins Guru
Wasn't my truck I was just the lucky tech that had to work on it. Third one I had to repair with snapped off pitman shaft. Always a 4X4 truck that was lifted with oversize off road tires. I just hope the new gear boxes hold up. The dropped pitman arm needs to be replaced also.
dan123dbl
02-13-2015 05:47 PM
1stgenfan
06-02-2008 07:56 PM
04ctd
10-05-2006 08:27 PM
DDysput
05-05-2004 07:44 AM
Quick Reply: Gear Box Issue
