G56 truck holds....
#32
Originally posted by Rocky
What is the difference between the:
G56 & NV-5600
G56 & NV-5600
various parts of the globe. The most noticeable change between the G56 and the NV5600 is the lower gear ratios, especially overdrive. This may cost you a few miles of highway range per tank. The G56 has been in production for about 2 years prior to Ram use, and DC is confident that it will stand up in Ram use."
The G56 also has a dual mass flywheel, instead of as single larger plate. Since this post, the G56's have been put on restriction as you've probably read here. Rumors have mentioned a couple of possible reasons, which you've probably also read on DTR. You know how it goes with new things....it can take a while to get the bugs out.
gatf4
26
02-04-2005 04:17 PM
Don M
27
10-17-2004 06:42 PM
