G56 service
Old 07-27-2007 | 11:19 AM
doznfire's Avatar
G56 service
Did a search on this but didn't find a whole lot. The G56 is ready for a service and I am wondering what the high mileage guys are running. Amsoil in everything including diffs and transfer case also? Or is there something else I should look in too?
Old 07-27-2007 | 01:21 PM
Roperteacher's Avatar
I have not used anything but the AMSOIL ATF in my G-56... Never has given me an ounce of problems..
Old 07-27-2007 | 01:26 PM
doznfire's Avatar
How many miles?
Old 07-27-2007 | 01:33 PM
D-Roc's Avatar
I will agree with Roperteacher for Amsoil ATF in the g56 as I have one and used Amsoil. But, I recently installed Redline C+ATF and noticed a DEFINITE MPG increase (small) and even a little bit more response on the pedal. The performance is about the same as far as shifting goes, though- so take your pick.
Old 07-27-2007 | 03:33 PM
mrblond's Avatar
How many qts are you puting in the G56? The manual says 6qts but I have read about people over filling?
Old 07-27-2007 | 04:35 PM
Don't get the overfilling issue confused with the NV5600 threads!! Some NV guys are overfilling because if you are towing up a steep incline the fluid starves the front bearings or something.. LOLOL The G-56 takes 6 quarts. I pumped in 6 quarts on level ground and it still didn't come ou tthe hole. I put in about a half a quart more and it began to run out so I plugged it and off I went!
Old 07-27-2007 | 05:25 PM
D-Roc's Avatar
Same with me.
Old 07-27-2007 | 05:42 PM
doznfire's Avatar
Sounds like I will be getting 7 quarts of amsoil and getting it done. You guys running the same in the transfer case?
Old 07-27-2007 | 06:05 PM
mrblond's Avatar
thanks, im going with a synthetic like the Mobil1 automatic trans fluid
Old 07-27-2007 | 06:18 PM
Yes, I run the same ATF in my 2002 transfer case. Between the 06 I had and the new 07 I only have about 20,000 combined miles on the ATF in the G-56.. lots of pulling and seems OK!
Old 07-27-2007 | 10:49 PM
D-Roc's Avatar
Same with me as well, running my choice in the TCase as well.
Old 08-08-2007 | 12:10 PM
doznfire's Avatar
How many quarts for the transfer case?
Old 08-08-2007 | 07:09 PM
D-Roc's Avatar
IIRC, I put in two and a bit or tight around two. It was pretty hot that day.
Old 08-08-2007 | 08:05 PM
Bswope's Avatar
Where is a good place to get Amsoil? Im coming up on my G56 change.
Thanks
Buddy
Old 08-08-2007 | 08:51 PM
doznfire's Avatar
Go to Amsoil.com, you can put in your zip code to find your nearest dealer.
steelblitzkrieg
10-14-2011 09:19 PM
MegaTony06
0
07-22-2011 01:06 PM
dieselbeef
06-12-2006 08:12 AM
Mexstan
09-08-2004 10:52 PM
Quick Reply: G56 service
