G56 failure
Old 03-17-2008 | 10:53 AM
Hounddog's Avatar
Was not there a TSB for popping out of reverse or such? I'd check for TSBs and warranty history on the truck.
Old 03-17-2008 | 02:56 PM
renopker's Avatar
Just wanted to let you fellas know the g56 2w and 4w are the same the 2w has a flange on the rear thats held in by a bolt take the bolt out pull the flange out and change the seal its now a 4w or change the seal install the flange and now its a 2w. been their done that.
Old 03-17-2008 | 09:16 PM
XLR8R's Avatar
The 4X4 mainshaft has a snap ring that holds the reverse gear synchro assembly in place.
Old 03-17-2008 | 09:51 PM
renopker's Avatar
There is only 1 main shaft listed for all apps and all snap rings are listed as all apps in the 06 parts manual am I missing something?
Old 03-18-2008 | 01:13 PM
XLR8R's Avatar
Yes, the mainshaft is the same, but the FSM specifies the snap ring as 4X4 only in the R&R procedure.
Per TSB 21-006-06, which applies to '05 & '06 G56s, the mainshaft bearing is held on by the snap ring for 4X4 apps, while the bearing is retained on the mainshaft by the yoke for 2X4 trucks.
Since the mainshafts should all have the snap ring groove, I don't know why the engineers felt the need to eliminate it for 2X4... it's cheap enough to use for all apps, and clearance shouldn't be an issue.
Who knows? I don't make 'em - we just make it better!
IPDiesel
07-29-2015 09:57 PM
dodgetrucker75
03-17-2011 09:15 PM
jrogers
290
11-11-2009 11:40 AM
UnrulyNFS
45
04-28-2008 10:10 AM
Colocrownie
07-21-2006 08:37 PM
Quick Reply: G56 failure
