G-56 Question
Old 06-08-2006 | 08:46 AM
GrandpasRam's Avatar
Originally Posted by SkyHarborCowboy
Here is the part I dont get. Max torque is around 1600-1700 RPM. Why is my truck doing 2200 at 68mph or so? I need an explanation for that one!
Joe
Max torque runs from 1600 all the way to 2600.
Old 06-08-2006 | 09:08 AM
jkitterman's Avatar
Cummins says that the engine should run in the 2150-2250 range at 65.
You can play with PowerSpec here.
http://www.powerspec.cummins.com/site/home/
Old 06-08-2006 | 09:15 AM
Nice tool, thanks for that link.
Old 06-08-2006 | 03:18 PM
DDahl's Avatar
I think if you check on the new 2007 Dodge cab&ch you will find that DC has quietly fixed the high gear problem with the G-56. I think they dumped the initial G-56s on us in 2005 knowing that the gearing was wrong and now have fixed it so that both the 3.73 and the 4.10 gears are available. Look at the new G-56 specs. for the 2007. 6th gear has more legs. (low balled again by DC).
Old 06-08-2006 | 03:40 PM
Luke S's Avatar
I don't think they changed it. I can order 07' Ram pick-up's right now, all ready ordered a couple. With the G56 the only gear ratio available on the pick-ups is still 3.73's. I can spec cab&chassis but can't order them, it will let me spec either 3.73's or 4.10's and I believe that reason is that some commercial customers in certain applications may want to gear the trucks even lower than they are now.
Old 06-08-2006 | 04:34 PM
DDahl's Avatar
http://www.turbodieselregister.com/0...0_Specs_EN.pdf
The above link is to DC Tech info on the new 2007 Cab&Ch
ratios NV5600 G56 Cab&Ch G56
1st 5.63 6.29 5.94
2nd 3.38 3.48 3.28
3rd 2.04 2.1 1.98
4th 1.39 1.38 1.3
5th 1.0 1.0 1.0
6th 0.73 0.79 0.74
reverse 5.63 5.74 5.42
From article in TDR
Old 06-09-2006 | 01:27 AM
pbajeff's Avatar
so, by that chart you ought to be able to get the gears then and and change out the 6th gear to get the higher gears right?
I also find myself fishing for another gear when I hit the highway on a pretty regular basis, I was just too embarrased to admit that at first.
mkeanglorldo56
11-04-2007 12:34 PM
Oval Racer
01-26-2007 02:57 PM
8mpg
05-08-2006 06:37 PM
donhov
12-13-2005 01:48 PM
Quick Reply: G-56 Question
