Fuel Pressure, Duration & Timing
Old 10-30-2006, 09:27 PM
sdarchery's Avatar
Thumbs down Fuel Pressure, Duration & Timing
DOES ANYONE HAVE A STEP BY STEP ON HOW TO ADJUST THE FUEL PRESSURE, TIMING & DURATION. I JUST PURCHASED A 2005 CTD AUTO AND AM VERY VERY DISAPPOINTED IN THE FUEL ECONOMY. I PUT AN EDGE CHIP IN AND MY MILAGE ON 1 IS 13.9 ON 5 ITS 14.6 IN THE STOCK MODE IT IS 15.2. THIS IS VERY SAD. I TOWED MY TOY HAULER THIS WEEKEND FOR THE FIRST TIME LOAD DOWN I'M CALCULATED WEIGHT AT 11,675 GOT A MANUAL CALCULATION OF 7 MILES TO THE GALLON. WENT 230.2 MILES ON 32.455 GALLONS OF FUEL. I'M LOOKING FOR SOME HELP, NOT SOME SMART AZZ COMMENTS ABOUT MY DRIVING AND KEEPING MY FOOT OUT OF IT. I HAVE DROVE THIS TRUCK LIKE A WHIMP TRYING TO JUSTIFY MY BUY A DODGE. BY THE WAY. ALL OF YOU GUYS WHO USE THE OVER HEAD CONSOLE TO FIGURE YOUR MILAGE, YOU SHOULD DO AN ACTUAL MANUAL CALCULATION. MY OVER HEAD MILAGE CONSOLE IS VERY INACURRATE. IT WAS READING 10 MPG.
Old 10-30-2006, 09:39 PM
masterphreak's Avatar
How many miles on the truck?
Any problems starting in the morning?
Check your oil and make sure there is not diesel in it. Also look underneath to see if there is any oil on the underside. Might have a bad injector dumping fuel in the oil.
If it doen't have many miles on it yet it might get poor mileage at first.
Old 10-30-2006, 09:53 PM
sdarchery's Avatar
Got 40,000 Miles On It, The Truck Starts Right Up And Runs Very Very Well.
What Does Desiel In The Oil Look Like?
No Leaks Underneath!
Old 10-30-2006, 11:07 PM
35" 05''s Avatar
u should not be getting that bad. maybe takin it back to the dealer and getting it re flashed might help
Old 10-31-2006, 04:36 AM
Dodgezilla's Avatar
Directions on adjusting fuel pressure, timing and duration:
1) Buy a fueling box
2) Install it
3) Start truck
4) Clean up mess
You can't really adjust these items without the help of a fueling box or downloader. You can add a little timing by getting a Rokktech crank sensor or doing the Tone Ring Mod....
Old 10-31-2006, 07:07 AM
MikeyB's Avatar
Did you have your speedo recalibrated with the larger tires? If not your calculations will be off due to larger tires and will have to adjust accordingly.
MikeyB
Old 10-31-2006, 07:31 AM
v8440's Avatar
What is your tire pressure? (I end up asking this on every thread I post in about fuel mileage issues. Nobody else ever seems to think it's important enough to ask the person having the problems. Wanna see an instant 2.5 or better mpg increase? Take a truck with 45 or 50 psi in the fronts and air them up to 80.)
Old 10-31-2006, 08:18 AM
sdarchery's Avatar
i was using the edge attitude for my actual speed which was 6 mph slower @ 65. but my speedo has nothing to do with 7 mpg towing my trailer.
Old 10-31-2006, 08:22 AM
sdarchery's Avatar
So are you saying the truck does not have any of these settings and the fix is an after nmarket part? I know about The roktech sensor but,
What is a fueling box?
What is a Tone Ring Mod?
Old 10-31-2006, 10:13 AM
jkitterman's Avatar
With your gearing and tire combo, you are out of the correct powerband most likely. How fast are you running, are you in overdrive, what is your rpm?
Old 10-31-2006, 11:39 AM
rockcrawler304's Avatar
With a 6" lift and 35" tires, I would say you are doing good to get 15MPG. With your truck set up the way it is you have a lot of variables that affect your mileage and how you need to calculate it. If all these are factored and figured out and you can still get 13-15mpg, you should be happy. Just MHO
Old 10-31-2006, 11:40 AM
MikeyB's Avatar
The odometer is tied the the speedo. So if the speedo is off so is the odometer.
If the speedo is 6mph slower than actual the odometer will read less miles than actually traveled.
MikeyB
Old 10-31-2006, 11:55 AM
Dodgezilla's Avatar
The Tone Ring Mod is just a free way to get what the Rokktech gives you. Do a search and you will find the instructions on doing it. It's pretty easy. Aftermarket fueling boxes and downloaders are what you need to get more duration, pressure, and timing out of your engine. There is no simple screw you can turn to get any of this.
Old 10-31-2006, 12:44 PM
RonsRig's Avatar
Get a Smarty and run it on programs 1, 2, or 3. You can try all kinds of different things, but if you want to see immediate results, get a Smarty.
Old 10-31-2006, 04:59 PM
DBLR's Avatar
What rpm and speed are you running at? Any thing over 21-2200 rpms will start to drop your MPG. Also with a 6 inch lift with 35 inch tires also eat up MPG. Not trying to be a smart a$$ but if this is your first diesel you don't drive them the same way as you do a gas engine. Use the torque, not the HP!
JMHO
Quick Reply: Fuel Pressure, Duration & Timing
