fuel pressure
Old 07-07-2005 | 10:03 AM
hbshortcut's Avatar
Question fuel pressure
This is my first post. I got all my gagues installed and operating fine. My question is the fuel pressure reads 9 PSI. at idle and about 8 PSI while driving at 50 to 60 MPH. If I put the PTM the pressure drops to just under 5 PSI and returns to 8 to 9 PSI when I let off, is this normal? I have 6700 miles in the truck.
Old 07-07-2005 | 11:05 AM
bigblock2stroke's Avatar
completely normal,
some guys report 0 psi with stock truck at wot
Old 07-07-2005 | 11:49 AM
hbshortcut's Avatar
Thanks for the reply. I had a 2001 prior to this truck, no fuel pressure gague, lift pump failed and damaged the injector pump (out of warranty) just wanted to be sure.
Old 07-07-2005 | 04:08 PM
bluebull's Avatar
perfectly normal, common fuel rail system uses less lift pump pressures, 03-05 trucks.
Old 07-07-2005 | 06:58 PM
Dodgezilla's Avatar
MIne drops to 0 psi if I floor it......
Old 07-08-2005 | 01:28 PM
Uhhh, just a guess, but you might be using a liiiitttttlllle more fuel at wot than he is
dodgeguy71
17
01-19-2012 12:52 AM
bigragu
01-24-2006 11:16 AM
mtl0727
11-05-2005 06:47 PM
darrenG
06-28-2005 07:43 AM
Flatty
01-05-2005 02:50 PM
Quick Reply: fuel pressure
