Fuel plumbing
Fuel plumbing
I want to add some gauges to the truck. I really want it to turn out clean. I think eventually, I'll have the pyrometer mounted on the A pillar and fuel pressure in the dash under the stereo (I saw a pic of a nice installation on here).
I just took some pics to make sure I understand how it is plumbed. Please correct me if I'm wrong.
This is where the fuel enters the filter from the lift pump.
In the pic below:
A - inlet to the hi pressure pump from the clean side of the filter
B - not sure, leakage back to filter for recirc?
C - hi pressure line to fuel rail
This is where fitting B leads to, what is it?
It looks like I can purchase the following banjo bolt with 1/8 NPT and exchange it with fitting A to wire the fuel pressure gauge to. Am I correct? This looks like the cleanest way to do it.
Dot, most of your thoughts are correct, except where the fuel enters the filter, that is to the left of the red circle that you had. The banjo bolt you circled and the one to the left of the filter on the front, are all the return fuel lines (return from pump, head, rail relief) ect.
Now, what's the deal with these two lines going to the back of the block?
I can't see what they're connected to.
#1 is the hi pressure line in both pics.
#2 points to the same line, it's one of the returns.
From below.
From above.
From below.
From above.
More evidence that someone has been messing around.
Definitely not a factory piece. The filler line is kinked a little bit.
Apparently, there's a checkvalve in this nipple because I don't see any fuel coming out of it.
P.J
10-28-2006 01:07 PM
Dieselcamper
12-01-2004 09:17 PM
Scrambler250
03-25-2004 06:39 PM
