fuel in oil 04.5
Old 08-01-2008 | 04:46 PM
gino23's Avatar
fuel in oil 04.5
fuel in oil 04.5
after 800 miles the oil is over filled by 1 gallon of fuel,325 hp ,64000miles
truck is use, for towing, the load is about 5000lbs. edge, intake, k/n, aurora
3000 turbo, banks exhaust, asi converter/large pan, 35in tires, still has the cat on it.
today complete dionostic, no leaks any where, they dyed and scoped motor and injectors, this was not a dealer. it was a cummins shop, the dealer told me the motor may not be broke in yet !!!!!!!!!! have other cummins the same
no problems!!!!!!!!!! help
Old 08-01-2008 | 05:01 PM
Roperteacher's Avatar
Sounds like an Injector stuck open to me. Maybe it closed back up before you got it checked out, but a gallon of Diesel in the oil can't be healthy. I WOuld pull the injectors and have them tested/Replaced. How is the oil coming out of the Vent tube under the truck? Lot of it? Usually when the crank gets full from fuel it runs out the bottom..
Old 08-01-2008 | 07:53 PM
dodgezilla04's Avatar
https://www.dieseltruckresource.com/...58#post2164858
careful roper. this guy knows it all. i told him the same thing you did, and he bashes me for it. 99.99% of the folks on DTR are great, this guy is the exception.
Old 08-01-2008 | 08:15 PM
chipmonk's Avatar
aw whatta you know, with your 4800 posts and your built CTD puttin' out 578 hp.
Old 08-01-2008 | 08:35 PM
apparently nothing, i guess my job as a cummins and cat instructor means nothing either.
Old 08-02-2008 | 10:12 AM
gino23's Avatar
hey dodgezilla
I said your advise was prices less!
because, dodge said the motor is not broke in yet at 64000 miles and it from towing all the time
the cummins people said the pump could not leak in to the oil.
I own them, drive them, i don't build them.
ounce again thanks for your advise
I will refer your advise to the dealer and cummins!
thanks GINO!!!!!!
ian515
10-16-2007 07:02 PM
TxDiesel007
15
01-18-2006 01:19 PM
Quick Reply: fuel in oil 04.5
