Fuel Lubrication Injectors?
I talked with a diesel tech on the phone today about the noise my 2005 CTD is making and everyone seems to think it is injector chatter that could be reduced by adding either tranny fluid or motor oil to the fuel.
Has or does anyone do this and does it work and which type do you use?
Much much better off running a diesel fuel additive like from Power Service, Stanadyne, Howes, Redline, Lucas, etc.
Today's ATF fluids contain friction modifiers which isn't good for the life of the injection pump and injectors.
If using motor oil use a non detergent type, or two stroke mixture oil.
MikeyB
MikeyB
I wouldn't add tranny oil to your fuel, big no no. I straight non-detergent 30 wt. probably wouldn't hurt. Personally, I would only use a good diesel fuel additive. 3rd gen injectors are expensive. Howes, Stanadyne or Power Service.
Thanks for the response.
The guy did say to use a "Type F" tranny fluid or a "30wt" oil, either one so as not to get the chemicals you all mentioned. He said after running the additive as you mentioned that cleaned the injectors then run the oil or tranny fluid; is this correct? I have just finished the tank with "Diesel Clean" from Diesel Power Services.
I run waste oil in my 95 and it does make it very happy. It is actually quieter than my 600 and has been getting better milage since I started running 10% WO. I would be leary of trying this on the Common Rail motors for no other reason than mother mopars warranty. Also as pointed out the injectors are expensive. I have seen that a few people are routinly running WO in their CR motors.
From experience...don't run the motor oil in the Common Rails.
See the thread that I posted about buying diesel fuel.....and getting engine oil with the diesel.
https://www.dieseltruckresource.com/...ad.php?t=83609
Try a mix of Power Service Kleen and Marvel Mystery Oil. I have used a mix in every tank for the last 25,000 miles. 3 parts Power Service Kleen to 1 part Marvel Mystery Oil. I add 160z of this mix to every tank. It did quiet mine down and runs smoother since adding the mix. Try a few tanks and see if it works, it will not hurt anything. You can search and find many posts on this combo of additives and many others. I am a believer.
Check this thread for moral support.
http://dieselram.com/cgi-bin/ultimat...c;f=8;t=000329
1 Post
Why use anything?
I talked with a diesel tech at the Cummins HQ in Mississauga, and he said you don't have to use any additives.
Also not recommended in owners manual.
I see a lot of folks running there own recipe (MMO and sutch).
Is there any hard science that this is beneficial or just heresay?
Beleive me, I mean no disrespect, as I have run an additive from the same place that said I did not need one.(Cummins)
For now I quit running addatives.
I don't need a scientific study, I know running PS/MMO makes my truck run smoother. It's personal choice. Considering the money I spent for my truck, it's worth the peace of mind to me.
Fuel Additives
Toto,
DC & Cummins don't recommend the use of additives but, Cummins sells a product called Premium Plus Diesel Fuel Additive Lubricity/Cleaner. Cummins is re-thinking a number of their theories since the new HPCR fuel delivery systems have arrived. Finer fuel filteration is among them, also.
I am one of the people with the injector knock problem that couldn't get DC to take care it. Finally, I started using an additive (Primrose Power Master 405). It took awhile but, the knock is now gone. That's the only thing I did differently.
The Bosch HPCR fuel injection systems should have been designed & built to operate on the available fuels, here in the US. I believe the majority of their experience is with European fuels, which, are of a much higher quality. Trying to operate these systems on our inferior quality fuels doesn't seem to work as well as they had expected.
The Ultra Low Sulphur Diesel (ULSD) seems to be hard on the HPCR, also. Does not seem to have enough lubricity.
The bottom line is that, in my opinion, the use of an additive is probably a good idea.
Joe F.(Buffalo)
Joe F.(Buffalo)
I have run waste oil, 2 stroke oil, 10w30, and Kerosene through my 3rd gen with no ill effects. Oh yeah and home made biodiesel made from walmart vegitable oil.
I have thought about running dirty dish water through it....
I've been told and read about adding bio-diesel (1qt to 10 gallons) to get the benefits of better lubrication and and reduce smoke and carbon. Anyone else hear about this?
