Fuel Leak... Need Help/Advice
I have a fuel leak that is coming from the front drivers side of the engine. There are two fuel lines coming into what I think is the lift pump (not sure). The leak is right in that area.
Here are some pictures.
If anyone has an idea of what most likely is causing the leak, please let me know.
Originally Posted by davelinde
looks like the CP3 (injector pump) not the lift pump.
mine was done under warranty... I think Bosch had a bad run of pumps.
Thanks for the info. Once I knew what it was, I was able to find tons of info about it. I have a dealer appt at 10am tomorrow.
My truck is only 1 year old, so the deductable shouldn't apply.
Based on what I have read about this, I think it is poor quality/engineering. There are too many variables in vehicle usage, fuel, additives, mods, etc. to isolate it and say "It is failing because...". The only consistentency I see is that it is happening in colder parts of the country.
Once I knew what I was looking at, it was amazing the amount of threads on this and other sites about this problem. Just search "CP3 leak". You can read for hours.
Originally Posted by Phatboy
The 3rd gens too? I thought the 2nd gens were the only ones with injector pump failures
And its not actually failed like the VP44 which left you stranded. It's a leak.
Big problem, yes.
Still not as bad as the 2nd gen vp44's.
Here is the outcome:
Took it Monday. They said they needed it overnight to determine if it was a leak or seepage. Tuesday they called and said it was definitely leaking and they needed to replace the CP3. They told me that since I was over 36k there was a $100 deductible. I told them they were mistaken about the deductible, that the Cummins had a 100000/5yr no deductible warranty. They conceded. It will be fixed by Friday.
Now the fun part. While I was there, I traded for a 2006 Megacab
How's that for fixing the problem.
boomerang
05-05-2014 04:44 PM
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
digbog
09-13-2006 06:19 PM
ryan466
08-30-2006 10:10 AM
