Fuel filter drain hose size?
I want to extend the drain hose down a little further so I can collect the drained diesel without getting it all over everything. Does anybody know the size(diameter) of the drain hose so I can go get a longer piece?
I did that modification, too. I just crawled under with a knife and cut off a couple inches and took it into the auto parts store and asked for 4 feet of this stuff...
Looking at it, it appears to be 1/2" ID, but taking a bit in with you with you will make sure they give you the same stuff.
Yeah, 1/2 is what it looks like to me, too.
I did the slip the bigger hose over the factory drain hose the first couple times, but it was just easier to replace the thing with a longer one.
I'm not super-green, but I didn't like the idea of diesel fuel going all over the axle and all over the ground. I really wonder why they didn't make the hose long enough to begin with, so you can easily catch the fuel from the drain in a pan.
