Fuel additive
Old 09-08-2006 | 10:45 AM
Lee S's Avatar
I've used Stanadyne since the first tankfull. I also add a little Marvel Mystery Oil at each fillup. With ULSD showing up, I'll probably increase the MMO.
Old 09-08-2006 | 12:06 PM
LFD2037's Avatar
I know alot of people use 2 stroke. Has anyone had any problems due to it? What about the 10, 20, or 30 # ND motor oil as far as prob's due directly to using it? I'm learning a good bit from this thread! Thank you.
Old 09-08-2006 | 01:46 PM
Pooter's Avatar
Where are you guys buying Stanadyne?
Been worried about it, since the low sulfer came out, need to start using some....
Old 09-08-2006 | 02:31 PM
TXTad's Avatar
Rather than adding oil, why not just get some biodiesel and add that?
Tad
Old 09-08-2006 | 02:50 PM
lamadera's Avatar
Tad
Only 2 stations in all of New Mexico have Bio, and it's 50 cents more a gallon. Otherwise that's a great idea.
Old 09-08-2006 | 02:59 PM
TXTad's Avatar
If you can get it, 50 cents per gallon more than diesel is still way cheaper than oil. You only need 2% to get huge lubricity benefits.
Old 09-08-2006 | 08:45 PM
LFD2037's Avatar
Tad
I was thinking about the same idea. It is the same $$$ where I live but I get worse MPG's w/it. I still fill up w/it about every 4th tank.
Old 09-08-2006 | 10:31 PM
TXTad's Avatar
If it's hard to get or very expensive, you can just use it as an additive. Apparently 2% is enough to make kerosene more lubricated than regular diesel. %5 should be more than enough to protect any truck from problems due to lack of fuel lubricity.
Zeppe807
25
11-16-2010 08:00 AM
rjmelehan
0
11-30-2009 01:02 PM
12-23-2002 07:42 PM
doodah
16
12-14-2002 10:20 AM
MARKY MARK
11-19-2002 09:37 PM
Quick Reply: Fuel additive
