Front Hubs ?
Old 02-26-2009 | 01:23 PM
SJL's Avatar
SJL
Front Hubs ?
when driving,coasting and applying brakes at low speeds front end shakes.front tires feel out of around at low speeds.at higher speeds i can feel and hear some bearing noise.removed the front hubs. bearings seem tight.i,m waiting for new hubs.any other ideas. thanks.
05 2500 4/4
Old 02-26-2009 | 03:23 PM
mini14's Avatar
jack up the front if your hubs are bad u can wiggle the tires @ 6 and 12 position. your rotors can be warped too, check play in hubs before spending on something u might not need. rockauto has the hubs cheaper then most.
Old 02-26-2009 | 04:27 PM
SJL's Avatar
SJL
im getting a wobble without applying any brakes and when i cost to a stop.when i brake at low speeds 10 mph and lower feels like lots of play in rotating parts. higher speeds are ok.
Old 02-26-2009 | 06:07 PM
NickBeek's Avatar
I had the exact symptoms you described once on a minivan, it turned out to be a big bubble in the tire. It only vibrated at low speeds.
Old 02-26-2009 | 06:21 PM
stickk's Avatar
When my hubs went out I would here a clunk when slowing to a light and also when taking off from a stop, no vibrations, just a clunk. I thought they were going out again, but it turns out that the center u-joint on the rear shaft was bad. It froze up in one direction. You would have to drop the driveshaft to check. It cost 250.00 at the dealer for 1!!!!!! u-joint. I had already signed for the 115.00 check it out fee because I thought it was the hubs and they would fix under the warranty since I had just had them done, but it wasn't so I just had them fix it. In the mean time I will be ordering ujoints for 25.00 ea and fixing it myself the next time they go bad.
SJL's Avatar
SJL
tires looked ok it feels like metal to metal
Old 02-26-2009 | 06:56 PM
Danderson's Avatar
Sounds like what I felt when I went to BFG AT's on the '99. Problem began and ended with mounting of BFG's and dismounting of same ,then mounting of Toyo's. No more BFG's.
Old 02-26-2009 | 08:16 PM
Jeff in TD's Avatar
Wouldn't hurt to swap tires front to back, just for giggles.
Are the ball joints slopped out?
Old 02-27-2009 | 09:44 AM
mini14's Avatar
only $25 axle joints ive seen were made in china from autozone
Old 02-27-2009 | 12:46 PM
stickk's Avatar
Advanced auto was 10 bucks. Heard of this site from another post. I don't know where they are made, Precision brand, but I doubt they are much diff from the OEM Dodge u joints.
http://www.rockauto.com/catalog/raframecatalog.php
It looks like Federal Mogul is the manu.
91oldranchtruck
01-31-2011 09:45 AM
Rattlerattle
06-06-2004 09:45 PM
keffa11
03-10-2004 11:56 PM
Quick Reply: Front Hubs ?
