front hub removal on 3500
Old 02-02-2009 | 08:39 PM
Farmall Power's Avatar
I have a front u joint out on the drive shaft, i have the brakes and rotor off, having a hard time getting the sealed up off, any ideas or tips?
Old 02-02-2009 | 08:45 PM
OOPS's Avatar
You do not have to take the hubs off to change a u-joint on the driveshaft, axles yes, d-shaft no.
woodrep's Avatar
First, soak the hell out of the mating surface area with penetrating oil. Loosen the four hub bolts about 1/4 inch and then take a socket and a stubby extension that you don't mind sacrificing and wedge it against the snout of the axle shaft housing. With the truck running, use the hydraulic pressure of the power steering and work the four bolts around with the steering wheel and pop that sucker loose. It will take a while, but it will come out. There is a few write ups with pictures if you do a search also. Hope this helps, it's what I did and it works. The first one took me about an hour to do, the second one took about 15 minutes.
Old 02-02-2009 | 09:23 PM
Thanks for the quick response, ill get the hub soaking and give it a try when i get home from work tommorow.
Old 02-03-2009 | 11:16 AM
billie's Avatar
The real key to this method is to work side to side on the bolts. The first few times may not show any movement since it is so minor, but it will move. Watch for tiny increments at first. Use a bumping pressure with the wheel rather than a prolonged push.
Good luck
Cya
Old 02-03-2009 | 11:34 AM
Dave2001's Avatar
Look in the articles section under 3rd gen for an article on ball joint replacement. This article has pictures of what is described by Farmall power and Billie. Use lots of penetrating fluid often as most of it will run off.
Old 02-03-2009 | 09:31 PM
I got it off tonight, put it back together. It wasnt as hard as it looked...now the other side will probably go. ;D
Old 02-04-2009 | 12:08 AM
woodrep's Avatar
Glad to hear it worked for you!
quicksilvr
04-09-2010 11:30 PM
Rafter B
01-11-2009 08:40 PM
johnny5.9
03-23-2007 04:39 PM
Crimedog
02-27-2007 10:39 PM
txs
08-10-2006 09:15 AM
Quick Reply: front hub removal on 3500
