Front end alignment
Old 01-17-2006 | 03:17 PM
Flastro's Avatar
Mine does the exact same thing, has since day one, just had the alignment checked last Sat at the dealer. its all within "specs" Tires on mine are not the issue as the first set did the same thing, Im researching adjustable ecentrics for the ball joints if there is such an animal. While doing the alignment we did find that the rear axle thrust angle is off.00214 .. not much, but could be an issue, but adjustment is not an option vs cost.
Im in the same boat and anyone with ideas ?
Old 01-19-2006 | 03:34 AM
DSLRammin's Avatar
Mine pulled right after I put on my 285 bfg's, It didn't matter what I did, I put on the Nitto 295's and now the truck drives straight again. Go figure
Old 01-19-2006 | 06:04 PM
jb903's Avatar
put new tires on about 2 months ago same size and i had the shop do an alignment and i got the death wobble??? after about 3 weeks it pulls to the right again but no more death wobble.
Old 01-19-2006 | 06:35 PM
Mexstan's Avatar
When my truck was new it pulled to the right and the steering was a bit stiff. The dealer found a bad steering box. They installed a new steering box and did and alignment and ever since then it has tracked perfectly.
Old 01-20-2006 | 01:05 AM
Hounddog's Avatar
A older TSB for 01/02s is a adjustable ball joint.It will fit the 03s up with a rubber shield installed.Some dealers DID install this to correct pull when the 3rd gens came out. Lots of posts about this early on.
onelugnut
05-05-2006 10:47 PM
P.J
12-03-2005 02:01 PM
mikelr
02-28-2005 10:19 AM
McNasty
10-12-2004 11:16 PM
dennisja
07-22-2004 10:36 AM
Quick Reply: Front end alignment
