Front Driveshaft Flange Bolts???
Anyone have any suggestions on removing the torx bolts in the front driveshaft flange? I have broke or bent every torx bit I have tried.
Thanks for any help.
Cummins Guru
I use Snapon torx drive socket and never had a problem with removing front driveshaft bolts using 3/8 drive impact gun. Blue Locktite is used on these bolts. Make sure any mud and dirt is cleaned out of torx bolt head and give socket a few taps with hammer to make sure.
Location: In Oroville, Ca., same house for past 46 yrs!
+1 on the heat. I used a small handheld propane torch.
+1 on replacing with socket head cap screws... plus lube since I used stainless.
I have already thought about this. When I have to take mine out, I will throw those bolts as far as I can and replace with SHCS. I never have figured out why they would use those in the first place.
Thanks for the input. Getting the snap on long drive torx bits so I can get them darn things out. Will consider replacing them with hex bolts, anyone know what the strength of the bolt should be?
If you want to replace the trox bolts, check this out:
http://www.cumminsforum.com/forum/3r...aft-bolts.html
BigDiesels
03-17-2011 07:19 AM
Got Smoke?
09-11-2006 10:23 PM
