Front drive shaft grease
Old 12-21-2009 | 02:58 PM
  #31
DirtEater's Avatar
Originally Posted by klx650a2
Nope, you want the doctor type needle to get past that stupid ball...
To get past the stupid ball you just need to push the needle in with a little pressure. The needle that lost lake posted works fine for me, I just can't find the darn things this time around.
Old 12-21-2009 | 04:33 PM
  #32
hector's Avatar
Originally Posted by Bill M.
I have a 07 5.9 liter. Does it have the needle grease fitting? Two different Dodge dealers, one in Canada and the one I bought the truck from says it does not have the fitting??
I have 07 5.9 & mine has it . I just finished removing & re-installing my drive shaft after greasing that small hole.It was hard to do on the truck & I couldn't tell if grease was getting to the spot. I don't think mine had ever been greased
Old 12-21-2009 | 07:20 PM
  #33
92'1stGen's Avatar
Originally Posted by Lost Lake
I have a needle like this... Does that other type that looks like a doctor's needle work better?
The "syringe" looking needle works better, it'll get the point of the needle inside the eyelet. Also, be careful how you move the needle, they break very easily.
Old 12-22-2009 | 11:13 AM
  #34
cromulius's Avatar
I will be taking on this task next oil change and as someone has said before I think the techs before probably just said "ya we greased it". After a newbie at the local oil change shop removed the filter on my civic and not the oil and just added more oil filling it to the brim I decided I cannot afford to let anyone work on my cummins. I have marine grease in my gun for use on my boats bearing buddies, is this grease cool for the dodge? Thanks
Old 12-22-2009 | 11:17 AM
  #35
klx650a2's Avatar
Yes, that grease will work fine...
just my opinion, buy a few of those needle grease tips, they break and bend super easy...
Old 12-22-2009 | 12:34 PM
  #36
ChrisJohnson's Avatar
I give mine a few squirts every time I change my oil (7500 or so miles). My driveway is sloped too much to jack up the front end, so I take the chance that the truck is in the position to grease the fitting. If it's not, I'll check it after the next time I move the truck. I use the needle fitting also, but I use one of those pistol grip/squeeze grease guns that you can pump one handed. I also use the flexible rubber hose type attachment. With one hand I stick the needle in the hole and press it hard enough to push in past the detent ball, the other hand holds and pumps the grease gun, and in my mouth, I hold a small pen flashlight to see what I'm doing. The first time I did it, it was tricky to find, but ever since then, it's been a breeze to do. Oh, and I do all of this on a creeper! That's why it does not bother me too much if the grease fitting isn't in the right position, and I just try again later.
Old 12-22-2009 | 04:59 PM
  #37
Bigiron's Avatar
If the grease for your Bearing Buddies is the blue marine grease, it is probably aluminum base instead of lithium base like automotive greases. I have been told that they don't play well together. If all the lithium grease was cleaned out first, I'm sure the marine grease would be just fine, but I wouldn't mix them.
Old 12-22-2009 | 05:22 PM
  #38
bansh-eman's Avatar
I also took some wax paper and taped it up all the way aroud my drive shaft after I filled my fitting. This allowed the grease to sling on the paper making it MUCH easier to clean up than letting it sling on my truck.
bansh-eman
23
02-24-2008 07:36 AM
SDHNTR
02-23-2008 10:32 PM
yank88
02-20-2008 01:04 PM
24seven
17
07-11-2007 12:23 PM
lakotacatwalker
04-10-2005 04:35 PM
Quick Reply: Front drive shaft grease
