Fluid Capacity in rear diff
If you are out of warranty,,,,,,,, Any of the quality Synthetics will, work,,,,, Aka,,, Royal Purple, Amsoil, etc
Any GL-5 rated synthetic gear oil in 75w90 will work great. I use Mobil 1 with great results.
You do not need any additives in our AAM axles. Just the gear oil.
Some people use additives to reduce/eliminate any chatter you may have while turning. Pay attention to the recommended fill level, 1/2" below the plug, or you will get leakage at the seal.
OP: I used Royal Purple 75w-90 because it was readily available, and I've been happy with it. It took just under 4 qts for the rear diff and just under 3 for the front.
Cummins Guru
If you are still under warranty I would use what Chrysler recomends, and don't forget to save your receipts. First thing any dealer will ask you when you bring your truck in with a diff noise. When was the last time you changed your fluid in your diff.
banana
12-01-2009 11:44 PM
LockedandLoaded
01-17-2008 02:51 PM
wreedCTD
09-07-2007 07:01 AM
Big Smoky
09-18-2006 05:19 PM
Relentless
10-06-2003 06:46 AM
