Fleetguard Oil Filters
Old 02-14-2007 | 05:10 PM
el toro's Avatar
What is the real difference (besides $3-4) in the Stratapore LF16035 filter and the standard Fleetguard LF3972?
I bought the Stratapore but not sure why I did. I must have fallen into the it's mo' betta if it's mo' 'spensive trap.
Old 02-14-2007 | 05:15 PM
P.J's Avatar
P.J
Fluted bottom. Since the new(er) model trucks make it so much harder to get to, they figure you should use a filter socket and extensions and come from beneath.
On my 2001 I used to be able to lean over the side and grad the filter with two hands and get it on/off no sweat, this 2006 is an entirely different beast.
I spun the hex out of the cheapo filter socket I bought when trying to get the OEM filter off......
I would get the newer style.
I have 2 of the 3972's on the classifieds, just decided to get rid of them rather than fight with em.
Old 02-14-2007 | 06:21 PM
el toro's Avatar
That's it? No internal difference?
Old 02-14-2007 | 06:26 PM
kelley15's Avatar
They are both fluted. the LF16035 is a stratapore the 3972 is a standard filter. The stratapore is better.
Old 02-14-2007 | 06:30 PM
kelley15's Avatar
The LF3959 is standard not fluted. The LF3894 is the strat not fluted.
Old 02-14-2007 | 06:49 PM
P.J's Avatar
P.J
D'oh.
Disregard my post, I got confused by the numbers.
You will certainly want the Stratopore over the standard. My point on the fluted bottom still stands though, the 3rd gens are tight up around the turbo/oil filter area.
Plus, I was using a LF3894 on my old truck, neither of the other ones.......
Old 02-14-2007 | 07:03 PM
kelley15's Avatar
We did a group buy on oil and fuel filters today at work ... So I am schooled up on it.
Old 02-14-2007 | 07:12 PM
belgianmagic's Avatar
the Stratapore filters more with less obstruction...easier flow better filtering
the filtering material is not paper like most other filters........CHECK THIS LINK OUThttp://www.cumminsfiltration.com/en/...ratapore.shtml
Old 02-14-2007 | 09:30 PM
Pooter's Avatar
I run the 3894s, no problem getting a oil filter wrench in there, I guess some guys like paying extra for the fancy flutted end
Old 02-15-2007 | 06:08 AM
P.J's Avatar
P.J
Ah, ya got me........ I like paying more......
Old 02-15-2007 | 07:10 AM
MikeyB's Avatar
What's a couple of extra bucks over a term of 7k miles.
MikeyB
Old 02-15-2007 | 10:11 AM
el toro's Avatar
3894? Huh? Is that for an older model CTD? Geno's lists the 3972 (standard) or the 16035 (Stratapore) as the filters to use for 03-07 CTD's. I've got a 16035 on right now and it seems to be running fine. I hope I got it right.
Old 02-15-2007 | 11:52 AM
D-Roc's Avatar
Stratapore's are synthetic media which reduces obstruction and the other one is conventional cellulose media. Stratapores are not better because they are more expensive. They are better because of the synthetic media and reduced obstruction. Less obstruction = better flow + filters finer particles = LESS WEAR.
Old 02-15-2007 | 11:55 AM
P.J's Avatar
P.J
LF3894 IS the 16035, just without the fluted end. That's what I was trying to say yesterday.
Old 02-15-2007 | 01:45 PM
Pooter's Avatar
Yep
A dollar difference between the two as well.
Quick Reply: Fleetguard Oil Filters
