First tank of fuel- average 12.03 mpg
Old 01-08-2007 | 08:03 PM
bucknasty's Avatar
Well, filled the Dodge up for the first time and was a bit suprised. I'm getting the same mpg that I had on my lifted F150(5.4), so I'm a little disappointed. I only have 422 miles on my truck so I hope to see some considerable improvement.
Question: When should I see some improvement in the mpg's?
Old 01-08-2007 | 08:19 PM
12PACK's Avatar
MPG improvement starts once you hit 423 miles. As you probably know, mileage will probably be less in the winter and one time last winter I only got ~ 12 on a tank, too. If you did alot of stop and go or short trips or had some fun with the skinny pedal, mpgs will be low.
I believe it improves once the truck worked a bit, or once you hit 15-20K. I'll be coming up on 15 shortly and I'm getting ~ 18 overall now, but I have the stick.
On your sig, you have 46RE, btw.
Old 01-08-2007 | 08:21 PM
Kawracer's Avatar
Just rolled 20k on my 06.....getting 20-21 mpg. Just give it a little time, I was getting about the same mileage as you are when mine was new. It will gradually get better mileage as you put more miles on it.
Old 01-08-2007 | 08:37 PM
cgraham's Avatar
I've got about 8,000 miles on mine and it's getting 15-16 around town and up to 20 on the highway. That's if I drive normal. Better than my Powerstroke ever did. Mine was between 12-13 after the first tank.
Old 01-08-2007 | 08:39 PM
rockcrawler304's Avatar
I have just over 13k on mine and avg. 18-19.5 hand calculated. Get to about 1000 miles and hook up a HEAVY trailer and tow for 100-200 miles (more if you can) and it will start to break in a bit faster. This helped mine but all I have is my Jeep on the trailer which = about 6000lbs. From what I hear 8-10000 lbs is best.
HTH and congrats on the new truck!!!
Old 01-08-2007 | 08:52 PM
adkl1's Avatar
I get 12-13 around town and my truck has 15k miles on clock and it has 7 trips with my 14k 5th wheel but i have the 4.10's so thats eating some of my fuel..
Old 01-08-2007 | 08:54 PM
djbikeman's Avatar
Don't believe what that overhead tells you.
I thought it was Fremont USA!
Old 01-08-2007 | 09:02 PM
danc46's Avatar
I've now got 1475 miles on my 06. MPG has averaged between 15.5 to 16.3 in a 50/50 mix of city and highway. My overhead comp says it's between 21.5 and 17.8 mpg. The overhead isn't too very accurate.
I'm not babying it, just driving normal. I fully expect it to go up as soon as I drive several hundred miles with a load up on the truck.
Old 01-08-2007 | 10:41 PM
bekim's Avatar
Personally, mileage tended to plane out around 20,000 miles. So you've got a few to go yet.
Mike
Old 01-08-2007 | 10:49 PM
dodgepower88's Avatar
Don't worry about it unless you have 30k and your still getting 12.
My dad just bought a new 06 and did the whole "pull the **** out of it" thing after 1000 miles and got 5 mpg on a 400 mile trip ( huge tank with unreal amounts of wind resistance!). Now it is starting to get in the 15-16 area empty at 3,000 miles.
There is light at the end of the tunnel.
Old 01-08-2007 | 11:44 PM
gRahAM Diesel's Avatar
I have 16.7k on mine and I am lucky to hit 15mpg's. Even on the highway at 72 (2k rpm) I can only hit about 17.5. My 05 QC same drivetrain configuration (and color to rule out any inconsistencies) would get 21mpg on the highway at the same speeds. That truck only had 18k when I traded it in so I am a bit disappointed in the MPG disparity between the two trucks. Although, the difference in mpg's is made up by the fact my kids cant reach the back of my seat with their little legs now
Old 01-09-2007 | 09:52 AM
socal 610's Avatar
I have 10,500 on my truck and the overhead is allways in the single digits the best I have seen out of this truck is 13mpg.I had the dealer reflash the computer and it read 14mpg when I left and by the time I got home it was back down to 11.2
Old 01-09-2007 | 10:13 AM
b.lee's Avatar
when people get new trucks they like to floor them, like me
thats most likely whats affecting your MPG's.
besides for the fact that the engine isnt broken in yet...
Old 01-09-2007 | 02:30 PM
Dartsport's Avatar
I have a little over 900 miles on mine. So far I have gotten between 16.2 mpg and 19.2 mpg. Hand calculated
Old 01-09-2007 | 02:39 PM
SWCBonfire's Avatar
My 2006 didn't break in until 25k miles or so. Maybe it's still breaking in, but I doubt it.
16 mpg is as high as it gets, constant use at 60-65 mph, no acceleration or stopping/starting. Go up to 70, it drops to low 15's-14's. If you pull even a small trailer at any point during a tank of fuel, it drops to 12 or less.
These amounts are hand-calculated. The overhead is extremely optimistic. I am pretty disappointed in the mileage this thing produces compared to my previous 3/4 tons, but it is a larger truck.
Quick Reply: First tank of fuel- average 12.03 mpg
