Filter Minder
Old 07-01-2007 | 02:26 PM
12PACK's Avatar
Filter Minder
How accurate are these? I'm ~ 40% towards the red in over two years. I have a new filter ready to put in, but should I bother with so much area left before I get near the red? Should I just clean out the housing and put the stock filter back in?
Thanks in advance.
Old 07-01-2007 | 03:13 PM
vzdude's Avatar
DTR's 'Go to Guy'
IMO the filterminders have never worked well. I usually use a visual inspection to determine if it needs replaced. By the time the filterminder shows restrictions the filter is toast!
Old 07-01-2007 | 05:38 PM
papaduck's Avatar
My filter minder is at 60% with 83,000 miles with the orginal filter. Almost 100% highway with about 25,000 towing my 5er.
I just installed gauges and am tryng to get a base line on the boost and then I will change the filter and see if the boost improves. Presently boost will go around 22-23 psi @ WOT around 2200 RPM.
Truck is stock except for gauges and turbo cool down timer.
Old 07-01-2007 | 05:48 PM
vzdude's Avatar
DTR's 'Go to Guy'
I have to clean my K&N about every 25k. I can't even imagine 83k on a factory one.
Old 07-01-2007 | 07:37 PM
Bark's Avatar
I know the book says not to check it or change it until the minder says to but dang it----I cant help myself. I have changed it about every 30k. I know, waste of money etc.
Old 07-01-2007 | 07:40 PM
vzdude's Avatar
DTR's 'Go to Guy'
^ I don't think of any maintenance item as being a waste. A dirty air filter is robbing MPG's and I would rather change something early than to wait to late! Just my philosophy FWIW.
Old 07-01-2007 | 08:35 PM
12PACK's Avatar
I hear you. I've got only 17K on mine, so maybe I'll clean up the housing and put it back in. I don't go offroad, on dirt roads or construction sites so I'm rarely near alot of dust. Smoke, yes, from time to time, but that's from the rear of the truck.
Thanks for all the input, guys.
Old 07-02-2007 | 03:11 PM
Sprinter17's Avatar
Muted User
I put a Fram filter in my truck and it's only a month old , clean as a whistle , but it pulls the minder into the red if I floor it one time. I f I reset the minder and drive normal it stays at about 25%. I hate to replace it already because it's real clean, but I think it's too restrictive for sure. I don't use Fram oil filters, but I figured they could make an airfilter, not much to them.
Old 07-02-2007 | 03:15 PM
jerry007's Avatar
My I never trust that mickey mouse thing. Just inspect it periodically. These engines pull a lot of air!!!
Old 07-03-2007 | 03:09 PM
jkitterman's Avatar
Reset the filter minder at oil changes and it should go back up to where it was before after a little bit of your usual driving. The are accurate indicators of filter restriction. Fleetguard says to go by them along with Donaldson, etc. If it makes you feel better, go ahead and change it when you want.
Old 07-03-2007 | 03:23 PM
Jezzhuntin's Avatar
mine is worthless. I bought a amsoil dry and just clean it every oil change, makes things easy.
Old 07-03-2007 | 03:27 PM
Roperteacher's Avatar
Everyone must live in a cleaner area than me!! LOLOL I put a new Air filter in every oil change just out of habit! They are cheap and mine get pretty darn ugly in a real short period of time. Filter minder is useless! LOLOL Rodeos and constant dust are not easy on a filter..LOL
Old 07-03-2007 | 03:28 PM
alMout's Avatar
The minder should never move with a clean filter, the one you have is too restrictive. I use a Wix drop in filter, rated around 675 cfm if I remember. I have never seen the minder move since I switched to this filter, even when it was a little dirty. Chunk that Fram and put in a Wix, what you gain in MPG will offset the couple of bucks you'll be losing.
Old 07-04-2007 | 11:36 AM
VaultRam's Avatar
I have the Amsoil Nano drop in dry filter and my minder is always pulled to the bottom. Not sure if its the torque tube or what but I usually reset it everytime I stop somewhere
Old 07-04-2007 | 12:28 PM
sellisrulzz's Avatar
even when mine says 100%, it still gets 20 mpg...
just changed the filter, and will see how long it takes to register 100 again. it moves every time i drive it. I was thinking of adding some vent holes. maybe its not getting enough air just thru the small fender opening?
Quick Reply: Filter Minder
