Fast Idle sticking
Old 04-24-2009 | 07:39 PM
JS1455v's Avatar
Fast Idle sticking
Please excuse me for asking another fast idle question as my first thread here on Dodge-Diesel. I did several searches but came up short of this question.
I have a 03 3500 6-speed with the 1000 RPM idle. My problem is that now it is sticking at 1000 RPM even when its not cold. Most commonly it does it when I am pulling into a drive way, when I have the throttle low at about 1500 RPM for a short distance and then stop. The RPM stays at 1000 RPM. It is also happening when in stop and go traffic. I have to ease out on the clutch and put a small load on the engine to get it to idle down. Tapping the throttle only speeds up the engine and then returns to 1000 RPM.
I'm not sure if this is related to the 1000 RPM cold idle or not as it is happening all the time. Have any of you encounter this problem?
Thanks
James
Old 04-24-2009 | 11:32 PM
Shepherd57's Avatar
Bump anybody have opinions mine is doing the same thing
Old 04-25-2009 | 11:57 AM
vj_M's Avatar
i know i just mentioned this in another post but sticking injectors?
does it ever idle down to 750? when u put strain on it? and when u do does it stay there until u rev it up again?
Old 04-25-2009 | 12:19 PM
Shepherd57's Avatar
When I come to a stop if I let the clutch out and put a bit of torque on with the brake on it will idle down. If I touch the throttle it will idle back up to a 1000 again.It seems to be a bit worse when the engine is warmed up.And sometimes it won't do it for a couple of days.
Old 04-25-2009 | 09:21 PM
jonny mopar's Avatar
mine does this once in awhile. if i let the clutch out a bit just like you do it drops down to ware its supose to idel. wonder why it does this?? mine only does it from time to time thoe.
Old 04-26-2009 | 10:35 AM
Shepherd57's Avatar
Anybody have any ideas
Jim Lane
12-07-2015 09:16 PM
EdmontonCanada
37
12-09-2009 03:18 AM
trik396
03-14-2007 07:57 AM
Scramblinman
11-29-2006 02:10 PM
TxDiesel007
01-17-2006 08:00 PM
Quick Reply: Fast Idle sticking
