Fass Titanium Lift Pump?
I am thinking of installing a Fass Titanium Series fuel pump with the new bolt-on mounting bracket. I still have the original style Carter pump on the filter housing. I have replaced it twice on side of the road, on Sundays, good weather and the luck of having safe parking spots. Spare pump and tools to change under seat. Takes me a hour to change. I have 75,000 miles on the 2004.5 Dodge. I have cut the old pumps apart each time and both look like new inside, but the brushes were worn out. My plan was to keep a new Carter pump with fuel line under the seat, then if the Fass did fail I could bypass it. Has anyone installed one on their 2003-2004 Dodge. Will the Fass throw any codes when installed?
The FASS should not throw any codes if installed correctly. The kit come with a wiring harness and relay that plugs directly into the factory lift pump connection. Also will come with an flange plate for replacing the factory canister mounted lift pump.
