FASS or Air Dog
Old 04-07-2008 | 01:36 PM
Rush Rider's Avatar
FASS or Air Dog
I am trying to figure the pro's ? con's for both, price,size,quality of kit and support, installation/instructions etc... also any difference in the noise level, I am planning to leave the exhaust alone (I think) and will not do more than a programmer/trans. upgrades. So basicly I dont want a loud pump.
Thanks for the input, Mike Bruns JBRacing.com
Old 04-07-2008 | 01:49 PM
HOBrian's Avatar
I would say get the Air Dog.
1. Lifetime warr.
2. I think the AD is still $499 for either the 100 or 150
3. Air dog is very quiet.
4. The Air Dog is smaller than the FASS.
5. If you have any questions just ask Mark
6. Directions are very good.
Old 04-07-2008 | 01:53 PM
53 willys's Avatar
my vote goes to the Airdog...It's Smaller, quieter and I can help you with ANY install questions you got too
size comparison...
Old 04-07-2008 | 02:34 PM
Rush Rider's Avatar
Pumps
Thanks, where do you suggest buying the AD system ? also what is the best choice for oil filters on the 2006 5.9 ?
Old 04-07-2008 | 02:51 PM
53 willys's Avatar
you can buy an Airdog from ME! of course
for oil filters I like
Mopar
Fleetguard
Baldwinn
Amsoil
Napa Gold
I say fleetguard tho for the most part tho...
Old 04-08-2008 | 02:18 PM
Rush Rider's Avatar
Air Dog on the way
I ordered the 100 last night and will do the mods as in your link, Is there anything else needed ? I was thinking about the filter bypass piece to clean up the compartment as well, where is that avail. ?
BTW Thanks Mark, Mike Bruns JBRacing.com
Old 04-08-2008 | 02:52 PM
Diesel-Dan's Avatar
Come on now....that pic is not a fair compairson at all. That is a 150 series, 200 GPH FASS. The biggest unit we make. It would be like me putting a 95 Series FASS next to a Fuel Preporator.
Also, any unit made in 2008 from us carries a lifetime warranty.
Old 04-08-2008 | 10:01 PM
woodrep's Avatar
So which one uses locally easy to find replacement filters and not one's that you have to specifically order? Meaning, can they be bought at the local Cummins or truck stop lube shop generally?
Wood
Old 04-08-2008 | 10:09 PM
mopardamo's Avatar
Hello,
Rush Rider for a 2006 truck I would not consider removing the stock pump if you are using it as a daily driver and a light tuner. The LP issue is a problem for older trucks than yours or for HP levels over about 450 on your 06.
Damon
Old 04-08-2008 | 10:15 PM
Fisherguy's Avatar
Originally Posted by mopardamo
Hello,
Damon
That's not true.
I can pullthe FP down to zero with my triple dog set to "extreme" (which is less than 450 HP).
Anyone adding any kind of chip or programmer should add something to get more fuel, unless they're okay seeing their FP gauge flat line when they punch it.
Old 04-08-2008 | 10:28 PM
woodrep's Avatar
Bump...filters.
Old 04-08-2008 | 10:52 PM
bluechrome's Avatar
Originally Posted by Fisherguy
That's not true.
You are incorrect I turned 505 uncorrected with a smarty and a 64/13 STOCK LP. Fuel pressure went down to 2psi. Look at the motor difference in the photos that mark posted. The fass is a 200gph @ 50psi which utilizes a much larger motor. Filters can be replaced with Fleetgaurds Filters.
Old 04-08-2008 | 11:25 PM
Fisherguy's Avatar
I'm not incorrect!
I'm just telling you what I see in my truck with my TD, 0 PSI.
... you're comfortable with just 2 psi?
Old 04-08-2008 | 11:36 PM
Festus's Avatar
^^^^^^^^^^^^^^^^^What Fisherguy said! With a tow module I can draw mine to zero in less than a heartbeat.
Old 04-09-2008 | 10:20 AM
53 willys's Avatar
Originally Posted by woodrep
Bump...filters.
Fleetguard filter crossover for the Airdog
Airdog Fuel Filter: FF5613 (3 micron)
Airdog Fuel Filter: FF5617 (7 micron)
Airdog Water Separator: FS19768
Quick Reply: FASS or Air Dog
